please help
please help
hello everybody im new here, so im sorry if i place the add in wrong section but i need all of you cayenne fans help here, i was a cayenne true fan for ages since i see it first time on the streets, since then it took my a while to get one but there you go im here with cayenne S 4.5 2003 in my back yard, first have to say was bit of disappointment to find soon once i bought it what engine temp is rising up when idle, looks like fan to my so far and i still have to get this done, just very busy with work at the moment, another MAJOR issue for my is what i cant find a sticker of gross axle weight and such on my cayenne and i need it to pass the test, i told might by its door was changed at some point due to damage or what ever in early years since im not the first owner of it, but there you go i just looked at another cayenne same year today and still cant find the sticker, was looking all around the doors and in the boot with a flashlight and i just cant find it, please advice if anyone know where its located couse im out of test and i need it done soon, thanks in advance
Temperature needle fluctuation may be "ok". Just let it idle and made sure it never gets 1/4 past the middle. After the fan(s) kick in, it should bring the temps back down. Also confirm no loss in coolant.
Probably just want to give Porsche dealer a call for the sticker location.
yea thats what im planing to do tomorrow, if we talk about temp it goes up around 95 which i think is way of the limit, i just tried that once but wont do it again, fan wasnt spining except for A/C fan which i turned up high to get temp down
and no coolant piping is replaced with aluminium ones, same as thermostat and water pump brand new too, any more ideas with fan testing, did it have fan thermo swith or its all computer regulated ?
yes im in ireland ,i was thinking about other countries regulations too, but if im right those stickers must by attached once impprted from another country if it ever was done so, im try to ring porsche today and see what they gone tell me .
no its not there either, guess i had realised to look there too its only sticker with info which is not related to the gross or axle weight anyhow
and by the way porsche garage was not much use either, couse all they told my is to check door here, door there i was expecting way more than that
Is it different that any other 955 S? Does an inspection procedure require some official to put eyes-on? Perhaps another forum member with a 955 S can post up the info?
