Kessy question
Kessy question
Hi
My 955TT has keyless entry and will lock and unlock on the passenger side door handles but only unlock on the drivers side door handles.
If i replace the drivers side door handles with used ebay items will I need a dealer to code them to the car?
RG
RG
Received 1,143 Likes
I suspect you might look under vehicle setup on your PCM. There is typically an option for unlocking - unlock just the drivers door first push of the remote - the rest the 2nd push OR unlock ALL doors first push of the button.
Changing the drivers side door handles will do absolutely nothing since that isn't where the unlocking logic is taking place.
Thanks.
I have the "all doors unlock" set up on the system. It's just the car won't lock when I press the button in either of the drivers side door handles.
Or is there something I don't know about Porsche prices
Sure, but when you replace those 2 handles they will still not work
Look up KESSY issues, the unit probably needs to be solder with new parts, but I would investigate further.
