08 Cayenne Starting issue (video/audio)
Old 05-20-2016, 11:49 AM
band99
band99's Avatar
Default 08 Cayenne Starting issue (video/audio)
Hi all,
I have a problem starting my 08 Cayenne. Battery was changed and I make sure the brake pedal is pressed hard. I also tried diff combinations of door closed, seat belt locked, pressing brake pedal, etc. (it was suggested in one of the posts). Nothing helps.
I created this video in winter and hoped the problem would go away when warmer outside but I am still experiencing the same.
Most of the time, the car will start between 2nd and 4th trial. Rarely will start 1st time, even if I had it running for 15 min. Sometimes I have to try several times (5+).
Most of the time, it's the issue that you see at the 12 and 37 sec
I almost never get an issue that you see at the 2 sec mark.
There, you can see that after I turned the ignition, the car didn't register it (I kind of don't want to focus on this issue since it really doesn't happen).
Any insights would be appreciated.
Old 05-20-2016, 11:53 AM
pbarch1
pbarch1's Avatar
This is how my starter failed. Went on like that for several weeks and then finally completely failed.
Old 05-20-2016, 06:21 PM
zonnie
zonnie's Avatar
whats system not active?
sometimes when i turn my key too quick nothing happens
Old 05-20-2016, 07:32 PM
band99
band99's Avatar
zonnie, it's not that something is not active. Take a look at the video at 12 sec to see the actual problem
Old 05-24-2016, 11:10 AM
69gaugeman
69gaugeman's Avatar
That's the TPMS not active.
That turns over way too slowly. You might want to go through the ground connections and the power connections before replacing the starter (It's under the intake manifold). If the battery is truly full and has capacity, it would turn over quicker.
Old 05-24-2016, 04:23 PM
band99
band99's Avatar
Default connections are clean
Just checked the main connections and everything looks clean. Pics attached.
Is there a specific place I should look for?
Perhaps one way to test is the voltage the starter gets when trying to start it. Is there an easy way to do this? Any tricks?
Old 05-24-2016, 06:13 PM
band99
band99's Avatar
69gaugeman, since everything was open, I proceeded to unscrew and put dielectric grease on main connectors. One screw was too easy so I had some hopes.
20 min later, I put everything together and still can't believe how quickly the car starts. So far so good but I will give it a couple more days.
Regardless, I owe you a beer(s) and a steak dinner. Let me know if you are coming to the GTA anytime soon.
Old 05-25-2016, 10:32 AM
69gaugeman
69gaugeman's Avatar
Got your PM and responded before I saw this. Glad it was an easy fix!
Old 05-25-2016, 02:06 PM
zonnie
zonnie's Avatar
keep posted here and show some pics! best of luck!
Old 05-27-2016, 11:26 AM
band99
band99's Avatar
Few days in... all is well. I am no longer embarrassed when parked besides an old Hyundai that starts right away while I was trying for the 3rd time
Quick Reply: 08 Cayenne Starting issue (video/audio)
