Alarm Siren - will this one work?
Old 10-27-2016, 01:50 PM
Jeff928S4
Jeff928S4's Avatar
Default Alarm Siren - will this one work?
Have to replace the alarm siren on my 2006 S.
Had the siren removed the other day and the part number on it was....
1J0 951 605A......(613.VW1507 for VW - same siren)
This siren....runs about $260 at Porsche, $140 at VW.
I entered that part number in Ebay search and was happy to find a new one for $40...problem is, in looked at it closer, I see it is actually a.....
1K0 951 605C......
The are pretty much the same shape, the 1K0 has a slightly more curved backside.
I know the three connectors are usually for....
1-signal, to CCM
2-ground
3-12V fused, to CCM
Would these be the same on both sirens or is the Porsche siren (1J0 951 605A - also used in the Touareg) the only one I can use???
Old 10-28-2016, 04:02 PM
Jeff928S4
Jeff928S4's Avatar
Well, it's on its way from China.
I guess I'll plug it in and see if it works. Will update if it does (much cheaper than other version).
Old 10-28-2016, 06:51 PM
Andy E.
The V8 Porschephile
Andy E.'s Avatar
Generally, VW part numbers are fairly easy to decipher and are similar to PAG & Audi's part numbering system.
The last digit of the part number usually describes the production or design modification code. "A" would designate a 1st generation part and "C" would be a 3rd gen design or production modification. If you look elsewhere on both parts, you will probably see a date code that's usually molded into the housing which also gives away the "new & improved" status of the "C" part in question.
A major modification would most likely result in new numbering of the "605" sequence of the component. (ex: 606, 607, etc...)
Old 01-10-2024, 06:19 PM
SafetyP1
SafetyP1's Avatar
Did it work ok?
Old 01-11-2024, 05:40 PM
jeff spahn
jeff spahn's Avatar
Originally Posted by SafetyP1
Did it work ok?
Holy thread resurrection batman.
Old 01-11-2024, 05:41 PM
SafetyP1
SafetyP1's Avatar
Haha, but did it work? Mines broken and OEM is £250!
Old 01-14-2024, 06:58 PM
jeff spahn
jeff spahn's Avatar
I bought one off amazon. worked fine. way cheaper than dealer. I very much royal pain in the *** to get to. much disassembly of the fusebox. your's might be much easier with your steering wheel and brake booster being on wrong side of car. Who knows.
Quick Reply: Alarm Siren - will this one work?
