Oil capacity on 2013 CS 4.8L data point
Just an FYI to add to the DIY knowledge.
Drained oil for over an hour, until there was only a single drip every now and then. I.e., Very thoroughly drained.
Changed oil filter.
Added exactly 9 quarts Mobil 0w40.
Ran engine for 10-20 minutes. Stopped engine. Let oil collect in oil pan for 5 minutes. Checked oil on PCM.
PCM showed oil at Max. capacity, but not over.
So, for my 2013 CS, 4.8L: 9 quarts was max. fill.
BTW, I do not mean this thread to start a discussion on how to check the oil level in a Cayenne. I just used the on board PCM.
Jim
Changed oil filter.
Jim
AudieO (09-18-2022)
Edit to above post:
After driving around 5-10 miles, my on-board PCM oil reading shows 1 bar below MAX.
Somewhere on the forum it says that 1 bar equals 0.26 quart.
AudieO (09-18-2022)
