Those of you with the dash compass and a 2011- can you display the time?
I'm considering a retrofit, but I want to know if 2011 models support the display of time in the embedded LCD in the dash compass. Thanks!
Received 1,143 Likes
Having added one of the clocks to my 2011 - it required coding it into the PCM that it existed. That was doable with iCarScan. It could then be setup on the PCM - with control of the lighting, and I seem to recall enabling it added a stopwatch and compass function to the PCM (not to the clock.) I do have one of the stopwatch instruments (used for the sport-chron) but never bothered plugging it in to see if the digital display will show the time, I can't imagine it won't. None of them will give Sport-Plus mode on a 2011, which is a shame.. I found it rather enjoyable on a loaner I had even with the V6 engine.
