TPMS - battery life
TPMS - battery life
We have run General Grabber AT2 tires for ~7 years now, not the same set. Will be getting fresh shoes,BFG KO2s, next month.
Our 2013 has the original TPMS sensors that still work. Would y'all swap out for fresh when the new tires get mounted?
Most of our driving is off-road and a very long way from paved surfaces. Understand that this is just an indicating system and that we can drive them to failure. Upon failure we would then have another tire remount to install new ones.
If cost was not a consideration would you install Porsche or after market sensors? --- Thanks!
Note, we now carry two full sized spares - one mounted to the tailgate, the 2nd on the roof as pictured here -
____________________________
https://rennlist.com/forums/cayenne-...meet-otis.html
Not sure about VW, but the big three target a five year life for the TPMS sensors. At 7 years, I would look to replace them. You can find the VDO (oem supplier) sensors on Amazon for $25.
As much of a PITA as it is to break the bead later to replace them (especially with the reinforced sidewalls of AT/MT tires), I'd swap 'em out while you have the wheel bare. I purchased ones under the Denso name, but in all reality, they were "Huf" sensors - $50/ea. on Amazon. Apparently I should have searched harder for the VDO ones! (Or maybe the price is just that different for the 958.2 compatible sensors?)
I bought my replacement sensors from tpms.com for a good price. In my case I had installed new tires about a year earlier so had to break the bead and have them replaced, which only cost me $20 as I had the tires rotated at the same time.. Looks like they currently have a set of Huf for ~$140 for a set of 4.
No affiliation other than a satisfied customer.
