Front differential replacement
Hi,
I have worn down the front diff in my mighty 2014 4.2 Diesel Cayenne. Apparently these break, mostly on Touareg's, but I guess our Cayenne's are basically the same car. I am not surprised looking at the outside of the differential, it seems tiny for the massive torque. I am sure it didn't help that I had mine optimized to 750 lb/ft of torque and 464 hp, but the grinding noise was there even before the tuning.
Anyway, I have sourced a used one, and need to replace it. Have anyone here done this on a 958? I am considering if I should do this myself or leave it to the shop. I am trying to figure out if this can be done with normal tools in a garage, and how many hours of labor it would be.
Any thoughts would be very appreciated!
Regards,
Johan Soderberg
Regards,
Johan Soderberg
Hi
Just done this very job on my 13 3.0 Diesel. Its not a bad job to do, I did it in an afternoon but if you allow yourself a full day with refreshments. I found a video of some 6 minutes on YouTube of a guy removing a touareg diff and just used this as reference. You need to lower the subframe just enough to get the diff out. I'm no mechanic, a competent DIY'er at best.
