How to make map follow vehicle movement?
This is kind of an embarrassing question as I'm sure the solution is pretty simple but here goes...
We use the map sometimes to figure out where we are geographically. Not navigation itself, but the map. If you just bring the map up it "follows" the vehicle wherever you go. But the moment you either zoom in or out then it stops following the car and you have to manually move it around to see where your current location is.
How do you enable the tracking of your car and movement of the map if you're zoomed in/out? I tried to check the PCM manual but I couldn't find any specific mention of it which is why I'm posting the question. Yes I know Google Maps and Waze can do this but I figured if I have the screen on the CTT I might as well use it.
Thanks!
Thanks!
