Trailer Harness Plug?
I need to tow something and have never really towed much of anything before and never with the Cayenne. I have an OEM tow package but don't understand the trailer harness plug. I unscrewed the 4 screws (which should have been stainless steel but weren't) and see the wires but don't know how to undo the cover from the plug itself - any help would be appreciated?
I went thru this last year when I was a noob to towing. You'll first need to remove the blank face plate - there's a small tab where you can insert a small flathead screwdriver to release the plate. From there you can buy yourself a which was recommended to me by other Rennlisters. I did my first tow with a small U-Haul which in turn required a
to plug into the Pollak and everything worked perfectly.
I went thru this last year when I was a noob to towing. You'll first need to remove the blank face plate - there's a small tab where you can insert a small flathead screwdriver to release the plate. From there you can buy yourself a Pollak 7-way socket which was recommended to me by other Rennlisters. I did my first tow with a small U-Haul which in turn required a 4-wire harness adapter to plug into the Pollak and everything worked perfectly.
They did not add a plug because this way you can decide if you want a 4 wire or 7 wire plug.
