Help - Replacing AC Blower Motor
I am trying to follow the excellent DIYs on replacing the AC blower motor. As usual with me, I can't figure out how to release the electrical connectors. I am working on the vent ducts on the passenger side. I have pulled the vents but I don't see an obvious release tab on the connector and I can't get them separated just pulling. I don't want to force it and break something. I assume I will have the same problem with the other connectors when I get to them.
Thanks for any guidance!
Screwed up my courage and played around with them. I figured the little stainless clips were involved, and finally figured out to use a dental pick and push on the little tab in the slot on the wide side of the connector. I had to push really harder than I thought I should, but it worked. The connectors disengaged. On with the project!
Nice, I got to this thread late.
Well, I just got to the next problem. I can't get the glove box out. It seems like something is holding it at the rear (front of the car). The video I looked at said you just have to move it around and pull it out. Mine seems pretty solidly connected to the car at the rear. I have pulled the three torx screws on the front and the one on the side, but the most movement I can get is to drop the front an inch or so. Even if I wanted to, I can't now get the pins aligned with the sockets to put it back.
What am I missing?
What am I missing?
Cayenne Forums Had the Answer
What am I missing?
What am I missing?
EDIT: Unfortunately, although the original post was about a 2016 Cayenne, the reply was about a 2011. I can't find any more screws on my car. Still can't get the glove box out.
2nd EDIT: They were there, I just couldn't see them. With them out, the glove box essentially fell out.
Last edited by awaschka; 04-18-2023 at 02:09 AM. Reason: Referenced post not for 958.2
.....Until It Ran Out of Cable....
Everything I found mentioned only 4 screws, 3 top and 1 on the side. Cayenne Forums had a post showing two more on the bottom front.
Al,
for my 958.1, the procedure I outlined goes in from underneath by removing the footwell cover and does not require R&R of the glove box. I am not fond of working on my back as it arcs over the door sill, but it is just a few minutes. Whether you remove the glove box or not, all screws for the blower motor assembly R&R are accessed from underneath. I am assuming that there was not a major change to he 958.2
If you stay your course, AllDataDIY has a procedure for the glovebox R&R Vehicle » Body and Frame » Interior Moulding / Trim » Glove Compartment » Service and Repair » 681519 Removing and Installing Glove Compartment
Mind sharing where you are located?
Ripking (04-18-2023)
Al,
I am in Fleming Island, FL which is South of Orange Park, across the St. Johns River from Jacksonville.
Al,
Thought that might be the case. As my spirit remains young, my body is telling me otherwise. Wish I was near ya as I would offer to assist.
My wife and I travel to the Tampa area for a couple of weeks in early fall in the 911. Really like FL in the fall.
I have 3 subscribed threads. One is mine. The other two are yours.
I meme I saw yesterday said I wish I could move around without sound effects.
Al
I am pretty broad shouldered and went from underneath too. It definitely required a lot of contorting my back to make it work but was able to get it out and a new one in without taking the dash out. I'm in my late 30s though, if I were older it probably wouldn't have been quite so easy (it still wasn't!).
Nothing Like Having the Right Tool
4 pick set from HD. Right angle pick popped it right out.
Wonder what the next problem will be.....
Better than $900-$1200 to have it done, I guess....
I wonder if the tech is only getting the 2 standard hours and the shop keeps the remainder of the charged labor hours? I am a capitalist at heart but there are some things that move the needle of my moral compass the wrong direction.
It took me about 2 hours to do the job because I took it slow, step by step, took pictures, etc. I suspect a tech that has done a couple of these walks to the tool box, grabs the only tools needed, opens the passenger door and in less than 30' is driving the car out of the shop AND should get paid for the 2 hours because his experience earned it. The second longest thing that might happen is waiting at the parts counter.
Rennlist, AllDataDIY and my favorite PIWIS-like tool have been a blessing.
and the next shoe has dropped......
The following 2 users liked this post by awaschka:
CAVU (04-19-2023),
RAudi Driver (04-19-2023)
