Headlight module where is located???
Hi, anyone knows where this afs module location is? 7PP907357 on the nemiga is showing with the headlights but I think is located somewhere inside the car? I’ve checked both footwells and it’s not there 🤷🏻♂️ thanks for any input. Regards!
no: 8 on the drawing
The modules are inside each headlight. You can see it by taking the bulb cover off for the bixenon projector. The left plug connects to the bixenon shutter. I don't remember if you can remove it without removing the projector (requiring removal of the front lens).
thanks but that’s not the one, this is some kind of power distribution module. The one what I’m asking is only one and managing AFS and both headlights but I’ve found some information in manual. It doesn’t say or show where exactly is but I’ve found sentence that it has to be remove switch console which make me think it’s in the central console under the all switches. Thanks anyway 😉
Did you ever find the location of the module? I'm looking for the location of the "Headlight Control Module"
