Fuel efficiency 4.8TT vs 4.0TT
I have tested fuel economy on my CTT 2014. And I am surprised that it can run 24mpg with 4 people on board and luggage I keep speed between 50-70ml. My friend has a CTT 2018 with 4.0 V8, and has exactly the same fuel efficiency. Strange, initially I thought that I can’t even be closer to fuel efficiency to new V8 4.0 I now it shuts down a cylinders at low speed.
Once the car gets rolling, the effort to keep it rolling is less, and neither engine works crazy hard.
I daily drive an S450 (a V6), and on the Mercedes forum I posted my mileage, and the guys with S560s (V8) get pretty similar mileage.
I am the new owner of a 2015 CTTS. First measured fuel economy, comparing gas receipts and odometer: 14.4 l per 100 km = 16.2 mpg. Disappointing. Especially because the measured tank was almost all highway cruising. Porsche's claimed highway mileage and the reports above indicate I should be getting some 40% more fuel economy.
TPM normal. Cool weather.
I did have a roofbox on top. Could that produce so much drag?
I recently moved on from a 2014 Cayenne S with the NA V8 to a 2024 Cayenne S with the twin turbo V8, and the gas mileage from the trip computer showed virtually identical results over identical driving routes. Based on published data, the new Cayenne S is about 200 lbs heavier. Mike
Just bought a 2017 CTT and I get about 19.4-19.8mpg avg (mostly) highway, but my average speed shows 73 in TX... When I got it 2 weeks ago it was about 18.5; ran a bottle of Techron through it and then a fuel injector cleaner on the following fill up as well, jumped it up to 20.5ish mpg (computer). YMMV but its a cheap option to try!
I wouldn't think it makes a HUGE difference, but it definitely will make A difference.
I will try an injector cleaner. Thanks for the suggestion.
Debatable... lol, Posted speed limit of 75 is typically running 80-85mph here. Which is why I thought it was running a little lower (and why I specifically said avg speed of 73, haha)... but then the Techron bumped that up running the same route at the same speed. Let us know if you end up seeing any improvements, I would be curious if its beneficial overall :-)
It's interesting how much difference altitude makes too. I bought my 2017 CTT in Denver, which is pretty high up, and driving home through the desert, the range remaining would say 560 miles on a full tank. I was getting around 25mpg and I wasn't gentle with the gas pedal. Here at sea level, the best I can do on pure highway drives with no traffic is about 22mpg. Driving up into the mountains, I get 18 mpg up, 29 mpg down. Driving a lot around town, my average is 12 mpg.
At sea level, high average temps (mid 80sF and up/30ºC and up), 70% stop & go traffic/ short distances, the other 30% in "highway with a lot of traffic" (average speed of 75km/h = ±45mph), I have averaged 12.71 mpg (18.51 L/100km) over the past 1,900 miles (3,000 kms) on my 2013 GTS. Tires are Michelin Latitude Sport 3 in the stock 295/35/21 size.
My consumption figures are based exclusively on actual distance driven (as measured by the trip odometer in the dash) and the amount of fuel put in at the pump. My onboard trip computer shows a fuel consumption figure that is "significantly" less than my measured result. My figures have already been mentioned, but as per the PCM summary page (mileage equates to what I have in my spreadsheet) the consumption is 15.05 mpg (15.63 L/100km).
Last edited by Gus B.; 02-27-2024 at 05:34 PM. Reason: added tire size & consumption method
For comparison, I typically get 22-23mpg on my standard daily highway commute, without a roof box of course.
