Headlight Control Module Location
I had my right headlight stop working due to water accumulating at the bottom of the housing and shorting out the LED module ballast, so I rplaced it! the new module did not light, so I figured that I needed to program the module (7pp941575pp). When I went to program the new module with my PIWIS 3, It could not recognize either front headlight. Finally, it indicated that the control module for the LED dynamic level is also defective, Part # 958-618-368-00.
My problem is that I cannot locate where this module is mounted! Anyone have schematics that locate this module, along with the various modules on the SUV?
Still trying to locate the LED dynamic level control module, also listed as part # 7PP-907-357G.
Anyone have info as to where this is located??
Thanks!
Thanks!
