Sponsored By:
Sponsored By:
2019 Cayenne Battery
Old 08-05-2023, 06:07 PM
  #256
PorscheACC
PorscheACC's Avatar
Originally Posted by kenv
Doing some quick math roughly 250,000 Cayennes produced world wide in model years 2019-2021. Avg battery replace/repair $3000. An extra $750 million in revenue. Add in all the 911’s too….way over a Billion $.
Plus add all the money they don’t to pay out for repairs from voided warranties.
That is assuming the battery is only changed once before the car hits the scrap
heap.
The accountants are running the show.
I have the original Lithium-Ion battery on my 2019 Cayenne, and now I am getting worried on Porsche applying that battery software update, if I visit my Porsche dealer.
I'll try to perform all my CS maintenance myself and avoid the dealer as much as I can, just in case and to see what happens too.
chassis (08-05-2023)
Old 08-09-2023, 01:24 PM
  #257
m0mo
m0mo's Avatar
Dealership is saying my low battery indicator isn't clearing with the battery software update. Car has been running / starting fine. is it only a matter of time?
I've replaced my own battery on other cars. Is this something that can be DIY?
Old 08-09-2023, 01:39 PM
  #258
chassis
chassis's Avatar
Received 1,230 Likes on 908 Posts
Yes, DIY is easy. To satisfy yourself of this, pull up the cover under the front passenger floormat. Arguable whether “registration” is needed via OBD. The OCD among us would use an OBD tool to register the new battery but my guess is no codes will be created if registration is not done.
Old 08-09-2023, 01:58 PM
  #259
m0mo
m0mo's Avatar
Good to hear.. They are quoting close to $3800 for the battery replacement. I believe the actual battery is much less
chassis (08-09-2023)
Old 08-09-2023, 02:02 PM
  #260
George718
George718's Avatar
Lithium Battery is approx $2,500 if you are able to find it....and i'm pretty sure you have to register it...not a DIY
Old 08-09-2023, 03:56 PM
  #261
m0mo
m0mo's Avatar
Guessing no one has tried yet?
I used to have a cable for my BMW to register a battery. Does Porsche have something similar?
Old 08-09-2023, 09:03 PM
  #262
chassis
chassis's Avatar
@George718 Are you saying registration is mandatory?
What are you saying is not DIY: a. battery replacement, or b. registration?
Old 08-09-2023, 11:52 PM
  #263
pinion
pinion's Avatar
The lithium battery has a canbus network connection.
While it would certainly be possible to make that plug and play I am also betting that Porsche won’t be able to resist doing a solid for their dealers and requiring PIWIS to correctly configure and assign the new battery parameters/network address for the car.
chassis (08-10-2023)
Old 08-10-2023, 12:45 AM
  #264
FlyPenFly
FlyPenFly's Avatar
Sounds like a big market opportunity for someone to come up with an AGM conversion kit and make a few million dollars.
I personally would rather pay $300-400 for an adaptation kit to AGM than $4000 from a dealer for something that'll just fail again.
The following 2 users liked this post by FlyPenFly:
chassis (08-10-2023), function12 (08-10-2023)
Old 08-10-2023, 10:13 AM
  #265
shustermeister
shustermeister's Avatar
Dealer service telling me that a sensor inside the battery is bad, not related to software update they performed in November to resolve low battery message. Trying to determine course of action right now. If battery needs replacement, and I am a few months out of factory warranty, will be interesting to see if Fidelity Platinum warranty covers it... the service rep tells me there are 3 other cars here right now with the same issue. Recall?
Old 08-10-2023, 02:41 PM
  #266
FlyPenFly
FlyPenFly's Avatar
I can't imagine it's covered under Fidelity when even the regular Porsche warranty doesn't always cover it. In most warranties, batteries are considered consumables.
edit: https://www.fidelitywarrantyservices...cle-protection
Looks like they specifically exclude batteries unless you have a hybrid.
Old 08-10-2023, 05:02 PM
  #267
shustermeister
Update: sensor inside the battery is faulty, causing the "low battery" warning. Tech said the Battery works fine, tests show all good. BUT, requires battery replacement since sensor cannot be replaced and the price is... $3100!!!! And I have to wait 4 days for the LiFe battery to arrive. Dealer denied factory warranty replacement of the unit, as it expired in March 2023, "sorry cannot do a goodwill on it". Good news, though, Fidelity Platinum extendes warranty I bought from Trenton Gibson has stepped up and has (after some convincing) approved the replacement with my payment of deductible, a paltry sum by comparison.Dealer gave me a 2024 Cayenne loaner for the weekend as long as the new battery arrives in 3 to 4 days.
Old 08-10-2023, 05:43 PM
  #268
pinion
pinion's Avatar
If it truly is the ‘sensor’ in the battery and they are not making stuff up… that’s pretty egregious as the shunt used to measure current in/out of the battery is less than $20 (500a shunt is about ~$15 on Amazon).
If you’re curious how state of charge monitoring works search for ‘Coulomb Counting’. If you go far enough back in this thread there are pictures of the inside of the lithium battery and the shunt is extremely obvious, right on top along the negative terminal. These LFP batteries are actually extremely simple and one the size of the Cayenne’s likely has a BoM of maybe $500.
Old 08-10-2023, 05:45 PM
  #269
E'TLS
E'TLS's Avatar
If an owner buys a brand new OEM LiFePO4 battery, installs it in the Cayenne, but without registering the new battery. Will the vehicle still run or not ?
Old 08-10-2023, 06:50 PM
  #270
chassis
chassis's Avatar
That is one question on the table. No one has reported a DIY LiFePO4 battery replacement on this site yet. I hold the view that the vehicle will be just fine without registering a new battery.
There are claims that alternator charging is modified or adapted by virtue of a new battery being registered. Stated reason is that a new battery requires less aggressive alternator current supply. I am neutral as to whether this is fact, or not.
E'TLS (08-11-2023)
Quick Reply: 2019 Cayenne Battery
