Coding Cayenne E3
#391
Through experiences from other members is how we avoid getting ripped off..
#392
Here's the settings I used to enable the "boost tube", and the ability to have the boost on the custom 4-line view.
Getting the boost on the custom 4-line view is a tricky affair. You cannot configure it via the custom settings on the PCM screen. It won't "stick". You must do the following: Configure the "Individual options line 1" settings (Launch/PIWIS), switch the view from Customized to Vehicle (using the steering wheel controls), then switch the view from Vehicle back to Customized. At least, that's the way it works on my 2019 Cayenne S with no Sport Chrono. I prefer the boost tube at the bottom of the gauge.
Instrument Cluster: Factory setting-Factory setting-individual options line 1: Boost Pressure (probably could use line 1, 2, 3, or 4, but I used line 1)
Instrument Cluster: Factory setting-Factory setting-individual options-Boost/Coolant: Enabled (I think this is necessary for the "Boost tube" at the bottom of the gauge)
Instrument Cluster: Factory setting-Factory setting - menu configuration-Performance: Enabled
Instrument Cluster: Factory setting-Factory setting - menu configuration-Sport Chrono: Enabled (this does not magically give your car Sport Chrono)
Instrument Cluster: Tube 4 bottom bar graph - bargraph: Boost Pressure (also necessary for the Boost tube)
Instrument Cluster: Factory setting-Factory setting-individual options-Boost level/value: Available
Instrument Cluster: Factory setting-Factory setting menu configuration-Boost: Enabled
Instrument Cluster: Menu configuration-Menu configuration right 2-Performance Monitor: Enabled (not sure what this does, might only be for hybrids?)
Instrument Cluster: Menu configuration-Menu configuration right 1-Boost: Enabled (there is also an entry for G-force) - I think this enables the drag/drop options for the custom view that you set via the PCM screen
Instrument Cluster: Boost pressure indication-Boost pressure indication 1: Enabled
Instrument Cluster: Boost pressure indication-Max boost pressure normal: 1.4 Bar (this is the default - I did not change this - if you flash your ECU for a performance boost, you may want to tweak this to a higher bar to show a broader/higher boost range)
Interesting sidenote: Front-end Electronics: Presentation mode of multicolor ambient and contour lighting: Enabled will force the colors to continuously cycle between available colors. It's about 2 - 3 color changes per second. Handy for demo, but irritating otherwise.
New menu choices for the Customized 4-line display. NOTE THAT BOOST DOES NOT "STICK" USING THIS PCM SCREEN
Boost Tube at the bottom of the gauge, and Boost on Line 1 of the Customized Display
G-force "Deceleration" option on the Customized 4-line display
#394
Has anyone else made this change??
Thanks, everyone, for the clarification/education. I haven't really monkeyed with those settings in the car, much less via PIWIS/Launch.
Edited - poor weather is my loss, your gain. I was bored.
Using my Launch x431: Instrument Cluster: Factory Setting-Factory setting units-Speed: change to "Unit_kmh". I did not go drive the car around after changing the setting, but the center/digital speed definitely changed to say "km/h"
Sorry for the crappy pictures, but I did not take my phone out with me. These came from the x431's camera (yuck)
Setting screen on x431
Before (set to Unit_mph)
After (set to Unit_kmh)
Also a question on it as it is a Canadian car. I had a dealer tell me the Canadian cars are worth less. Any reason or truth to this??
#395
Supercharged
Hi There, I have a 2022 Targa 4S, and am looking to buy the Launch to make this change. Has anyone else tried this, did it work ok? Is it simple to find the lines and change it????
I assume your 2022 would behave similarly,
As for Canadian cars being worth less… sounds like your dealer just wants to blow smoke up your butt.
#397
Instrument Cluster is "Kombi", select that, then go to manual coding without rules and scroll around until you see the German equivalent of "factory setting" and then find the values I listed (the German equivalent). It's not hard.
limbo (10-17-2023)
#400
did you find a solution to the error codes?
So I have been trying to disable *** on the new cayenne 2023 using a genuine pt3g vci v2 and piwis 41.8. I can access the modules just fine but when I try to change the block05 and block08 in the dme module pertaining to the *** feature, it’s not able to change the options. I have even disable the component protection feature as well, but I still can’t change the ***-related options.
I have tried going to f7 addl menu route and changing the vo of the car to disable *** and the auto coding procedure also fails.
has anyone successfully disable *** on the new 2023 cayennes?
#401
Unfortunately no. I have asked around and it seems there might be some of type protection lock on the engine dme ecu module preventing any type of changes, even with genuine pt3g. I even tried unlocking/disabling the protection feature for the module and it still won’t alllow me to change those settings. Hopefully someone else has figured something out
#403
Cayenne 2019
Hi All, newbie here, i’ve shipped my cayenne from USA to europe and was wondering if there is any chance to update the digital (highlighted) from ml to Km? the analog is already showing the km but i would like the digital to show the same thing.
was also wondering if auto on/off can be disabled?
#404
I know it's painful, but I recommend reading this whole thread.
Here are some examples to get your started:
https://rennlist.com/forums/cayenne-...l#post17470752
https://rennlist.com/forums/cayenne-...l#post17261429 (but read this post, too: https://rennlist.com/forums/cayenne-...l#post18973734)
Good luck!
#405
For those that have enabled Wireless CarPlay through coding AND has upgraded their iPhone to iOS 17.x, does the SharePlay icon now appear in the Music app in CarPlay?
