Coding Cayenne E3
#406
Hi All, newbie here, i’ve shipped my cayenne from USA to europe and was wondering if there is any chance to update the digital (highlighted) from ml to Km? the analog is already showing the km but i would like the digital to show the same thing.
was also wondering if auto on/off can be disabled?
I'm driving my car in Europe for more than a third of every year, rest is in the UK. I do that all the time, if you can't do it, then it's probably a USDM issue.
#407
#408
Check my post - updated to show how to change the digital speedo on the center gauge:
https://rennlist.com/forums/cayenne-...l#post17261429
#410
Coding system location
Hi,
does anyone in the St. Louis,MO or Madison,WI area have the piwis or launchx431 system? Would like to get my 2019 cayenne coded to have wireless CarPlay but on the fence with purchasing a system just for that. Would be great if someone familiar with it could assist.
much appreciated. Thank you
#411
Hi,
I have some questions about Cayenne E3 Coding.
I did retrofit of rear view camera.
I tried to add it to equipment list and after this I marked all ECUs and clicked on automatic coding (PIWIS 3) and this killed the Cayenne (MY 2019).
I translate: "Error when evaluating the f-tab. Softwareversion is: 0907 Partnumber 9Y0 920 945"
In cluster I got: "All-wheel drive system failed, only rear-wheel drive adapted to continue driving"
I removed the rear view camera at the equipment list, and did it again, but nothing changes... DTC`s are deleted but in 0x22 I got the failure "wrong vehicle variant", this DTC is permanent.
Is there a solution to solve it by myself or can only Porsche code it back again...
Thank you guys
Thank you guys
#412
Hi,
Thank you guys
Thank you guys
One of your module lose its coding.
#414
By now the version you are using is probably up to date, but I would check that too. What model dongle you are using?
Of course, keep that voltage at a proper level with a juicy charger (at least 75A). Another common source of coding failure.
#415
I have 41.400, but after checking my version from another member you were right that some modules are missing.
I have VCX and Gysflash Charger (100 A).
Alternative would be to change to OEM VAS6154A.
I will update to 41.800 oder newer and then I try to code everything new.
Can someone help me perhaps remotely when I have updated my PIWIS?
#416
Turrrbo (01-06-2024)
#417
Thanks to @rnlst_log !!
He solved everything and also coded my rear view camera retrofit the position of the gateway...
#418
Couple of things done. Airbag activate/deactivate disclaimer is gone. Added sport chrono (Laptimer) for the right screen menu. allowed for keyboard and full music access with CarPlay in motion.
Added off-road and sport chrono to the HUD.
Activated expert menu.
I'm almost certain that one can customize what on which screen to have info. Eg, navigation map on the left, car info on the right and so on. It seems all the fields are vastly customizable.
Android auto is there. Not sure if added hardware would be required.
#419
Is it possible to change how low temperatures you can drive in e-mode on hybrids before the ICE starts? My car reports that e-mode is not available when the temperature drops below about 28-29 degrees F / -2 degrees celsius.
#420
