Turbo GT Thread - MY2024+
#136
Hi!
Can you please post some pics of your '22 TGT with '24 taller tires on it? How is you speedo behaving (if you compared it with gps before/after)? Any rubbing?
I'm pretty sure there's no difference in arch sizes for 22/24 models, but still curious about your experience. Thx!
BTW 31" tires are the best upgrade on MY24 models, so much more proportional!
The following 3 users liked this post by jlee504:
#140
#141
Anyone that's had the first gen turbo GT and now has a '24 GT...can you give some pros/cons? Trying to decide between the two. I would rather pick up a 22/23 that's already had the majority of depreciation already knocked out, but if the newer gen is worth it in terms of changes, then I'll go for that. I wish I had some near me to try out but I don't. Thanks!
#143
Sell the Macan Turbo PP for a TGT?
I love my Macan. I love the smaller size, I love that it drives more like a sport sedan than a CUV, I love the PDK.
My SA planted the TGT seed and now I'm starting to give it serious thought.
There is no reason to sell the Macan other than it is a 2017 and things may start to come up soon. Then again, it only has 38k mi.
I appreciate how 911s have managed to stay relatively light. The Macan is not bad at 4,300 lbs. but the Cayenne is 5k lbs.
I'm concerned that I'll miss the PDK, that the car will feel too big, too heavy and too much like an SUV.
I haven't driven one and won't get a chance to.
I'd appreciate hearing from TGT owners with decent seat time in a Macan Turbo or newer GTS.
#144
#145
I had a Macan Turbo similar to yours and it's a huge huge upgrade. they don't even drive the same or feel the same, its going to be much firmer than what you have so you have to be ok with that and there is a lot more space. it will handle heavy but very tight at the same time, the macon was much softer. and the engine differences are night and day. the turbo was fast and smooth, this will be more raucous and with a lot more grunt.
Wilder (04-11-2024)
#146
Originally Posted by jlee504
just based on the reviews it sounded like the mild upgrade except for the suspension probably being the most notable. Wasn't worth losing an analog tach and actual shift lever for me..
#148
Is the suspension adjustable? I will be using it in rough roads and prefer the normal (softer) setting in the Macan in things like cobble stone or bad roads.
#150
In addition to changes in the interior and exterior cosmetics, the new Cayenne GT also has a completely different 2-chamber suspension and, as a result, different tire sizes. The Turbo e-hybrid now also has a modified engine with mono-scroll instead of twin-scroll turbochargers. I don't know if this modification also applies to the GT engine, but it would seem logical to me to improve the engine in this model as well.
