Warming up in the winter
How are folks managing with cold starts in terms of ideal temp to move on? It’s a cold engine bay these days .
Is there an idea temp before shifting to gear? Also since it’s a hybrid I’m find myself having some EV anxiety where the battery is running low and I know hybrids about to kick on with a cold engine
In traditional vehicles I wait for the cold idle to drop to normal before setting off and then I keep the RPMs reasonable until the oil reaches operating temperature. With a hybrid your ICE will obviously experience more cold starts and longer hours operating below optimum temperature but that is just the nature of the beast.
In the situation I know I will be using ICE i preheat my car over the app ( have e-hybrid) for 5 to 10 minutes ,sit in the car put in the sport mode.The engine will come up and after RPM settle down( it will take maybe a minute) switch back to E/Hybrid.
that way I know oil did got to the to the all parts of the engine ,then I drove away and let the cars decided whenever will use E mode or ICE
Needsdecaf (01-22-2024)
Idling to warm is a myth.
it’s busted here https://rennlist.com/forums/cayenne-...mediately.html
what oil operating temp should we target?
I just finished break in period on my 2024 base coupe and did the initial oil change. I have been waiting until the oil temp is 200° F to do any exciting driving. I picked that temp because I noticed when I initially drove the car the 500 miles home the temp on the hwy was 204°. Recently when our temps were low 20s I noticed the car never got over 195 on a long hwy drive. So I assumed at that point I could consider 195 operating temp.
Do you have the Porsche Connect app? You can set the departure timer so the Cayenne is charged and preconditioned for when you leave. It will warm the battery and interior for you. If you are out and about you can set the Cayenne to precondition off the HV battery, Just use the icon with the heat and symbols to the left of the key symbol at the lower third of the screen. It takes around 30 to precondition. It will drop your r-range but at the same time max it out since the battery is warmed. Sounds counter intuitive but it works. That was part of the problem up in Chicago last week with EV's m not charging. The batteries needed to be warmed up to accpet the chgarge and many of them were all ready toast when they pulled up the the chargers. You will notice up to a 30% reduction in e-range in the cold. These batteries are sensitive to excessive hot and cold temperatures. You might even see a message showing "epower" not available even though the gauge will show that the HV battery has a charge.
We don't get much cold weather here in TX. But we have over the last 10 days. The e range is decidedly less (likely mostly due to battery and cabin conditioning). So I pre-conditioned the car on the plug before leaving. If I knew that I was going to get close to the car kicking into ICE mode, I.e. a trip of more than 15 miles, I simply put it in hybrid and drove with enough vigor to get the engine to come on and warm up. But if I knew that it was just a short trip, I didn't bother and just left it in EPower and made sure the engine didn't come on.
I live in a place where we have -30C nights and -18C days during the winter. Morning starts aren't a problem for me as I park in a heated garage. When I leave work after the car has sat for 6 hours at -18C ( 0F), I start the car, let it idle for about 20 seconds and then put it in gear and drive off slowly until the exhaust flaps close (exhaust quiets) and then drive moderately until the engine reaches normal operating temperature.
I have done the same with every car I have owned since oil went to synthetic (before that I plugged in a block heater). I've never had an engine problem although I tend to get a new car every 3 or 4 years so I probably wouldn't know what happens long term.
