It's New So It's Better - Right?
I have a 2019 Cayenne that I decided needs new (replacement) floor mats - so I ordered them.
When they arrived, I immediately noticed that the design of the new rear mats had the anchor connectors removed from them. (The male portion of the connector is of course present on the floor of my car and causes the mat to not lay fully flat.)
This is an example of what happens when a company permits accountants to make final product decisions.
How many other things (that you can't see) have been similarly "updated" in order to reduce cost?
I think a Porsche is worth owning, but things like this give me a bad feeling about the company.
2019 Cayenne. New rear floor mat on the left. Original on the right.
There's a German accountant with a pocket protector and handheld calculator that I need to thank for this...
I just looked at one of the connectors again. It may be doable.
But looks like there's a good chance it will crack / break in trying to separate the top from the bottom half (due to being brittle related to age / exposure to heat inside the car.)
i386_64 (04-27-2024)
I'm not really sensing much difference in the weight or mass of the mat itself though - with the exception of course of the anchoring connector.
chassis (04-27-2024)
Was there an option to select ones with and without the female plastic doohickey? Not being a butt and saying you're an idiot, but maybe there is a choice these days.
Either way, that is sucky that they don't have that on them and they won't exactly lie flat.
Seems an easy job to punch a hole in the new mats and transfer the old female sockets to the new mats.
If the old female sockets break, spending more than 15 seconds that I spent, would yield the right Volkswagen or Audi part:
https://www.ebay.com/itm/32595164493...RoC8_kQAvD_BwE
Woofman (04-28-2024)
The mats without fastening clips are the version for MY2024.
Turn the them over and compare the part numbers old vs new. If they are different, ask the seller to exchange them for the correct ones. I am sure that there are still mats available for the pre-facelift version.
For pre-lift model set of black mats should be: 9Y1863011AOS5
For MY2024 models set of black mats should be: 9Y1863011BOS5
Grey has last 3 letters: OU6
