Does adding layeers of sealant increase longevity
Old 11-11-2017, 02:40 PM
Diamond Dog
Diamond Dog's Avatar
Default Does adding layeers of sealant increase longevity
Many sealants tell you they last 6 months. They also say you can layer. So if yo put on 2 coats would you get 12 months?
Old 11-12-2017, 12:13 PM
Bxstr
Bxstr's Avatar
Received 2,974 Likes on 2,051 Posts
You wouldn't get 12 months, maybe you would get 8 or so months by adding the second coat.
Old 01-02-2018, 07:30 AM
TOGWT
TOGWT's Avatar
Location: London,UK / Florida US State- Dazed & Confused
Product durability relies on the cross-linking bond a product makes with the paint, both sealant and coating bond / crosslink best with a 'bare' paint surface.
A sealant will of course bond with another layer, but the solvents used to help 'spreadability' will dissolve the layer it's applied too
Applying another layer will not extend the longevity, quite the opposite (see above)
Old 01-02-2018, 03:46 PM
Marine Blue
Marine Blue's Avatar
The only reason to add a second coat would be to insure that you covered all the surfaces. As noted, the solvents in sealants will remove any existing sealant during application.
Rule of thumb, two thin coats.
The better approach would be to apply the sealant every few months, that will give you the best protection.
Quick Reply: Does adding layeers of sealant increase longevity
