A 'step up' from a sealant
Location: London,UK / Florida US State- Dazed & Confused
“A ‘Stepping Stone’ to using a coating”
http://togwt1980.blogspot.co.uk/2017...g-coating.html
Optimum Gloss Coat is a hybrid coating consisting of SiO2 (silicon oxide) and SiC (silicon carbide). a protective clear resin coating, similar to the clear coat that already exists on your vehicle. It can be applied to all exterior surfaces. It is not recommended for glass since improper application can affect visibility. For other exterior surfaces, it is a highly effective, transparent, permanent coating that keeps your vehicle looking like new.
I love this product for ease of application. That said I have had mixed results. On a 2016 street car with nice clear coat it works great. On 2002 race car that also has a street car paint job it did not hold up so well. Simply did not last. Same on my truck. Truck is white and quality of the GMC paint job is not the same as street car. All three cars were well prepped prior to installation. What do you think is happening? Perhaps it bonds better to newer paint formulas? That is about all I could come up with.
Received 5,389 Likes
TOWGT, I always appreciate your information and contributions to Rennlist.
I use OGC on my wheels and calipers every year, during wheels-off prep, before winter hibernation. My only challenge is to portion out 10mls for 4 fat-*** wheels and 4 big reds.
There may be silicon residue that is preventing proper bonding
Thanks for the reply, and like others have said, really appreciate your contribution as I always learn something. Typically the last step is a polish of some type. Menzerma or P21 or Meguiars. Will try using a wax stripper/cleaner and then OGC. It is a wonderful product.
Paint Surface Cleaning
Chemical (solvent) - formulated with solvents and / or very fine abrasives (Kaolin or China Clay) Most of their cleaning ability is provided by the cleaning solvents, not the polish. Used to remove old wax, embedded dirt and light stains from paint; they help to restore gloss and remove light surface imperfection (oxidation, paint stains, marks left from bird excrement, water ‘spots’, and etc). They are designed to be used as often as required without measurably reducing paint thickness. Some paintwork cleaner’s act as 'All in One' products, so not only do they clean and polish, but also provide limited protection
Optimum Paint Prep™ is an excellent cleaner for removing polish or old wax before applying any of coatings or waxes. A combination of mild solvents dissolves and removes all the contaminants and leaves the paint squeaky clean and ready for the final protection. Will not leave any marring of the surface and does not contain any oils or surfactants and leaves no residue behind.
P21S Paintwork Cleanse, a gloss-enhancing chemical cleanser that contains fillers (Kaolin or China clay) will remove old wax, light swirls and oxidation. It can be applied by hand or with an orbital polisher. Paint cleaners are designed to remove old wax, oxidation, embedded dirt and light stains from your paint surface. They can remove micro-marring of the surface (i.e. light towel marks) but typically will not remove imperfections that require levelling the clear coat, but can remove some oxidation and mineral deposits.
Chemical solvents paint cleaners are good to use if you want to prep the paint surface prior to applying a wax (without polishing). My preference would be to use an IPA or DuPont’s PrepSol as it doesn't leave any (silicone / mineral) oils or etc behind, as these can cause problems when polishing or the application of a coating if they are not removed
Swissvax Regular Cleaner Fluid - an advanced paint preserving solution containing heavy polishing oils that will refresh the paintwork and does not contain abrasives. Cleaner Fluid has to be applied before the first Wax application and easily removes swirl marks, light scratches, tar spots and tree sap as well as old wax and other residues and provides a smooth and perfect surface as an essential basis for the wax application.
Can you suggest a pre-coating polish or cleaner for a car that has a LOT of vinyl graphics?
It's a challenge to work on the paint without touching the vinyl.
