Paint Touchup - Dr Colorchip and Loew-Cornell
You can also tape around the chip, then use the micro brush, but again without the white tip. Then use Dr Colorchip seal act to remove the paint, but do it very lightly otherwise you'll pull the paint out of the chip. I've found the tape around the tip helps to keep things contained within the chip.
https://www.chipmonkeysinc.com/monke...d9y_VhPw8ZuhsU
These are great for chip repair
https://shop.benco.com/Product/3978-...lavender-box-o
Make friends with your dentist. Got about a dozen of these when I got a crown...only cost me $1,800.
