car cover
Super Moderator
Needs More Cowbell
Needs More Cowbell
Indoor or outdoor?
For indoor use, I like either the Porsche (European) Tequipment spec car cover (colored Porsche crest, VERY soft interior lining, very lightweight and extremely well fitting) or the cover from Gert at Carnewal (rennlist sponsor).
IIRC, they are both made by the same company, the Porsche cover is light grey only, Gert offers various colors
http://www.carnewal-europe.com/cpx_p011.htm
FWIW, I've got 2, one for the 996TT and one for the 968Cab.
Location: London,UK / Florida US State- Dazed & Confused
Protect your investment with a car cover, outdoors, car covers offer unequalled protection against ultraviolet radiation (UVR) they are manufactured to be water-resistant and are available in various breathable fabric materials that provide protection from acid rain, pollution, bird excrement, tree sap and wind blown debris, as well as protection against every type of climatic conditions, can be used for both long-term indoor or outdoor vehicle storage.
Covercraft Products are well known in the automotive industry as the largest manufacturer of custom patterned car covers in the world. Started in 1965 as a two-person company, now with over 500-employee’s supplying the automotive after market, original equipment manufacturers (OEM) and speciality markets with over 45,000 custom cover patterns, made in the USA with the QS 9000 standards rating award, meeting strict international quality standards. They offer a four year replacement warranty.
Websites- http:// www.carcoverworld.com/ Europe-http//:www.covercraft-europe.com
For relative ease of handling choose a cover with a fabric weight of between 4-7 oz per sq. yd. Used for long-term vehicle storage, either in the garage or outdoors, car covers protect against accidental scratches and dings from passers-by, car doors, lawn mowers, sporting equipment, bikes and pets.
Product Selection:
Vehicle Storage
Indoor:
Dustop TM- 4 layer (polypropylene / polyethylene composite spun bond) cover with maximum dust protection and its soft inner layer protects paint. Light and easy to handle, prevents dings, for inside protection from dust and dirt, ideal for indoor vehicle storage or as the primary cover of a two-cover system (see Strong Winds or Desert Dust Storms)
Long Term Outdoor:
WeathersheildTM HD- primarily for intense sun environments and long-term storage provides optimum protection from water, dust, tree sap, while providing long-term UVR protection and maximum weatherproof protection from a multi-layer breathable (heavyweight) fabric.
Outdoor Weather Protection
For fabric see Outdoor Fabric Guide – http//:www.covercraft.com
All Weather:
WeathersheildTM - single layer construction, maximum weatherproof, superior dry time, breathable, scratch-less, durable, easy care, and packs small and light made from a durable breathable polymer fabric, provides protection from UVR, acid rain, dust, dirt, intense sunlight and wind/storm proof up to force 8 hurricanes.
Severe Rain Storms: EvolutionTM (TechnalonTM)- a heavyweight, four-layer fabric ultrasonically bonded to provide more water resistance than most covers as well as UVR protection for extended outdoor use, but especially heavy rain protection. Places a soft, paint protecting finish against the vehicles surfaces, also provide impact protection from nicks, dings, dents and scratches.
Inclement Weather: NoahTM by Kimberly ClarkTM — one third less the material weight of the EvolutionTM cover, a three-layer fabric ultrasonically bonded to provide more water resistance than most covers as well as UVR protection for extended outdoor use, but especially heavy rain protection. Places a soft, paint protecting finish against the vehicles surfaces
Strong Winds or Desert Dust Storms:
Gales or strong winds and desert dust storms can buffer the car cover causing surface marring, wind blown sand, dirt or grit if it gets between the paint surface and a wind buffered cover will cause surface scratches. To avoid this use a Dust Stop™ as a secondary cover, this tight fitting cotton fleece lined material will protect the surface, then use a Weathersheild™ as the primary cover for weather protection. Both of these covers are made of a breathable material so moisture or condensation will not be trapped between the covers and the surface
Two-cover system:
During high winds or prolonged storage the use of this system will avoid paint surface marring from the cover being buffered by high force winds (Hurricanes)
1. Dustop TM Four layer cover with maximum dust protection and its soft inner layer protects paint from marring
2. WeathersheildTM - single layer construction, primarily for intense sun environments and long-term storage provides optimum protection from water, dust, tree sap, while providing long-term UVR protection and maximum weatherproof protection from a multi-layer breathable fabric.
Convertible Interior Care:
Sunbrella™ by Clen Raven Mills, Inc.
Easy to use protection for convertibles when the top is down, the interior cover protects the windshield and the vehicle interior from UV radiation, the suns heat, airborne pollutants, and droppings from trees and birds.
Because of its unique construction process Sunbrella® provides protection, and years of service, in intense sun areas, like Arizona, Florida, and other areas of the sun-belt, where UV rays will rapidly degrade the paint and interior or your car, truck, SUV or van.
Some fabrics offer more heat insulation than others, simply because they are multi-layered and are more effective at keeping heat away from the vehicle surface, but any cover will help reduce the vehicle temperature on a hot day. They are manufactured to be water-resistant, available in various breathable fabric materials for protection against every type of climatic conditions, as well as both long-term indoor or outdoor vehicle storage.
Useful info on the Porsche indoor cover, thanks (I'll inc in my book)
Product Selection:
Vehicle Storage
Indoor:
Long Term Outdoor:
All Weather:
Two-cover system:
Location: 40 min South from the 'Ring, 45 min East of Spa
I use the Porsche factory cover on my 987S and it does the perfect job in protecting my car while it is clean. It's a snug fit and ultra soft polyester underside as well as machine washable.
