classifieds |
membership |
rennlist |
photo album     sponsors | upload photo | chat | marketplace     |
| Register | FAQ | Calendar | Search | Today's Posts | Mark Forums Read | Used Cars | My Recent Topics | Vendor Directory |
Thread Tools |
#1 |
Rennlist Member |
hey guys. OT suggested some of you may have some excellent advice on cleaning plastic interior body panels.
These panels will be removed. I am considering using warm soap and water drip dry and I am confused on the type of conditioner to apply. WWYD?
www.orioncdc.com "Item, qe nul soit si hardy de crier havok sur peine davoir la test coupe." Cry 'Havoc,' and let slip the dogs of war; That this foul deed shall smell above the earth With carrion men, groaning for burial. |
#2 |
Rennlist Member Join Date: Sep 2006
Me personally I would get a good brush and mix some sort of all purpose cleaner like Optimum Power Clean to a low dilution like 5:1 with distilled water (assuming the pieces aren't too dirty). Give it a good rinsing and make sure you dry it well so it doesn't water spot.
Since they are interior pieces, you should go with a plastic/vinyl protectant from Einzsett or maybe 303 Aerospace protectant. It depends on how much gloss you want...do a little research on this forum to find out which product looks the best to you. Hope some others will chime in. I like Einzsett's product in that it lasts a long time and is not too glossy, but it is a bit too slick/sticky and does attract a bit of dirt.
![]() GT Silver 2004 911 40th Jahre edition PCM2, heated memory comfort seats, 030, 220, x51 Power Package Past (and sorely missed!): E Stock Alpine White on Blue 1989 944 NA 2.7L 8v. Options: 030 (Sport Chassis) 220 (LSD), short 5th, driver sport seat cloth. Sold to JohnTorg 03/2010. |
#3 | |
Premium Sponsor
Rennlist Site Sponsor Join Date: May 2006
Quote:
http://www.glisteningperfectionstore...ttle%2C/Detail As for conditioning, I like einszett Vinyl Rubber Care or Swissvax Protecton. The einszett does have a real slick feel but is easy to work with. Use either product with one of our GP Applicators, and wipe of with a microfiber towel after 15 minutes to give a satin finish. http://www.glisteningperfectionstore...Care%2C/Detail http://www.glisteningperfectionstore...x-vinyl/Detail
Rennlist Members use Promo Code rennlist to receive 10% off entire order Follow Moe HERE |
#4 |
Rennlist Member Join Date: Jul 2004
There are many specific products available for interior cleaning, most work well and will get the job done. I personally like Griots Interior Cleaner
Protectants such as 303 Aerospace, Einzett, Griots Vinyl/Rubber and a few others are excellent. They protect with UV Blockers without adding too much shine.
Afshin 1990 GT, Marine Blue / Linen / Rootwood (The Beverly Hills Car) 1987 S4 5spd, Marine Blue - Gone to a Good Home
#5 |
User
Location: London,UK / Florida US State- Dazed & Confused
Cleaning Vinyl
Like all detailing task’s the correct preparation before applying the product will ensure that it works correctly, and has both durability and aesthetics. Iz einszett 'Plastik-Reiniger' is an intensive, non-corrosive, non-acidic two-phase deep cleaner for vinyl trim and urethane covered automotive upholstery, that removes grime build-up thoroughly and effortlessly, these chemicals restore your interiors original texture and resiliency; use to clean all coloured and clear water-based acrylic polyurethane covered automotive upholstery; this product is biodegradable, formalin-free and environmentally friendly. Wash vinyl surfaces with soapy water and rinse with clean water and then thoroughly dry. Then use 1z Plastik Reiniger before the application of a suitable dressing. Protection - with 1z einszett Vinyl Rubber Care & Potectant "Tiefenpfleger” provides a temperature-resistant seal and a low-shine matte finish Dust-resistant and retards the fading effects of UV rays to keep exterior ‘rubber’ and vinyl looking like new. Application - Spray onto a clean micro fibre towel, agitate lightly and then wipe dry Vinyl and hard plastic surfaces- (including the dash) apply any dressings very sparingly as these surfaces don’t allow the dressings to penetrate very well. Apply a suitable matte type dressing (Iz Cockpit Premium) to ensure that there is no reflection on the windshield, thus reducing visibility. Alternate with a UVR protection (303™ Space Protectant or Optimum Protectant Plus) especially to the dash and any other surface that is subjected to sunlight on a regular basis Virtually all vinyl manufacturers agree that (Dimethal Silicones (DMS) should not be used on vinyl (See £Rubber Dressings” - Solvent -based silicone dressings) |
| Tags |
| 1z, care, clean, cleaning, einszett, optimum, panel, panels, plastic, power, protectant, restore, rubber, shampoo, vinyl |
| Thread Tools | |
