waterless wash and wax experience?
I have access to water hose but still want to have a second option while it's in the garage. Any of you tried this before, what do you think?
Nice product, I picked some up this past winter. I use it for light cleaning. I also drop a capful into my wash bucket even if I rinse. Really lets water sheet right off.
It's awesome. I've been through a gallon over the years. I had to use it for a couple years when there was a "drought" in NC. It really does work unless the car is really dirty. I also drop some in the wash bucket to help contaminants fall to the bottom of the bucket. Get a "grit guard" to go with it!
I've been using Optimum No Rinse for 5+ years and I can recommend it for sure. Great product. I haven't 'washed' my car in years unless it's properly dirty. ONR is fantastic.
You should wipe the panels straight up and down to minimize any swirling. With proper care and the two-bucket method, I've never introduced swirls to my finish after paint correction using ONR. I just ordered a gallon of Adams no-rinse, going to give that a shot to see how it compares to ONR. No reason other than trying something new after 5+ years.
Order it!
Order it!
Thanks guys. I tried a cap full with about 16 oz water. Sprayed the hood really wet, let it sat for a couple mins, that swiped the surface gently with clean micro clothes. Dry with another clean dry MC. I did the hood and the back end. It seems to clean well. I have been hand washing and waxing cars for a quarter century, getting so used to the smooth waxy buffed surface afterwards. After ONR, the surfaces feel dry as if there's no coating at all. I figured at the concentration much higher than instruction, I should get some sort of coating. Am I doing something wrong, or if this is how it's supposed to feel?
Spraying panels and wiping isn't how it's supposed to be used for washing, that's just for quick detailing. Dilute it in a bucket of water, with a separate bucket (also with a cap full in it plus grit guard) for rinsing your wash mitt. Soak your mitt, wipe the panel, pat dry with waffle weave MF towel right after. Then move on to next panel.
The ONR will not leave any finish on the paint - you'll need to wax the car for that. ONR is also available in a version that has liquid wax in it, it's the green coloured version. That would leave a slick coating afterwards.
Chemical Guys V7
Adams Detailer
Poorbooy's Spray & Gloss
Poorboy's World QD+
Finish Kare 425
That list basically goes from easiest to use to more difficult. The difficulty basically coming from smearing and the need to wipe and buff more.
Ill use it or Ultima Waterless if I want to take the car out and it has been sitting and collected some dust. If it is actually really dirty from driving, I will do a standard wash.
HUMP
HUMP
It's not the product(s), but the technique that really matters. Most, all, rinseless wash products works great. (I use Adam's) The key is "common sense". It works fine on car with light dusting, slight dirty. Not mean to be use on a real dirty car. Also, pre-soak the panels with the product first to left up the dirt and less chances for scratching. Lastly, go to YouTube and search for Garry Dean wash method. That's the best rinseless wash method IMO. No chances to reintroduce any dirt onto the paint!
I use rinseless wash when our cars is only slightly dusty or ran through rain after a wash. Or in the cold winter time when water freeze up outside. In fact, I just washed our cars last weekend using rinseless wash. It's a great quick maintenance wash product IMO. Major time save, and as save to use as anything given the correct method.
I believe you should go for Ultima Acrylic Waterless Wash because it really gives a glossy look. Try it & let me know your feedback.
