AiM Math Channel Video
Rennlist Hoonigan
which cost no drachmas
I put together a quick video on how to use the math channel functions in AiM and go through setting up a corner radius channel.
I've also put up the math channel documents that Roger Caddell from AiM has put together for people who attend his seminars. Please take a look at all the info, then dig into some math channels.
If anyone has questions - post them up! Let's get people using some of the more advanced functions in Race Studio 2 Analysis!
Thanks for posting - very useful!
Basic Site Sponsor
Basic Site Sponsor
Received 2,886 Likes
Bill, select the tab for your session at the top left of that window. THEN, you can use YOUR channels in the equation!
-Peter Krause
www.peterkrause.net
www.gofasternow.com
-Peter Krause
www.peterkrause.net
www.gofasternow.com
Rennlist Hoonigan
The error you received is that the channel name the equation is looking for is not available from your logger. So, click on the tab that says "BillGT413102016" in the math channels window. Then you'll be editing the math channels in your test session. Use the lateral acceleration channel from the identifiers list and you should be all set.
Once you have that working correct, go back to the general tab and change the AccLat part of the equation to whatever your logger has it named.
Important Part
The general tab is applied to every session you open in Race Studio 2. So, make sure those channels have the correct name so that they automatically work when you import a data file. That will save you from having to fix them every time you import a session.
Let me know if you have any other problems.
Matt,
I entered a number of the math channels related to recording time, distance and percentage of coasting into a session and am now trying to get them into the General tab so they'll insert automatically into session files when I load them. Coasting is definitely an issue for me. Reading your Important Note recommendation above and trying to accomplish it. Problem I'm having is the identifiers included under the general tab, don't include the particular identifier names from the session tab and thus don't work when tested. I'm sure there is a very simple reason for this that I am missing.
Thanks in advance. BTW, the Gsum channel I entered months ago does show up under the General tab as well as the Aim_G_Sum channel that I don't use.
Rennlist Hoonigan
The sure fire way to put the general math channels you want is to create what you want with a test open, then export those math channels. Close the test, then go Modify>math channels and import the set that you just exported. That will put them in all sets that you open.
The other way that I'm pretty sure will work is to use the transfer box. I've posted a picture of how to do this below. It will also work between different open tests, so you can add math channels you created before to older tests.
Thanks man, I'll dig back into it tomorrow. May get a chance to meet you at Tremblant sometime in the future - we just bought a summer house on Lake Champlain north of Plattsburgh, NY (my home town, though I moved to FL in '75) and while it will take a while to absorb the upfront costs of the transaction, I'm hoping to get the P-car up that way and try some tracks with more elevation change than the moguls at Sebring!
Rennlist Hoonigan
We normally hit the July 4th NER event at Tremblant, but I won't be able to make it this year. I have to find another event up there. If you make it to the Glen, I'm there a bunch too.
It's great your trying this!
Important Part
Important Part
Basic Site Sponsor
Basic Site Sponsor
Bill, in your post above with the picture of the dialog box (#4), click on the square to the left of the Channel Name and then you can change it. Be sure to "Apply"
Rennlist Hoonigan
Attached is a photo of the button to to change the channel name.
Basic Site Sponsor
Basic Site Sponsor
I think we just said the same thing. Using different words...
Ok, I'm trying to add the Gsum channel also. Under the session tab in math channels window, the Gsum formula has errors unless I change AccLong to Longitudinal_a and AccLat to Lateral_acc When I paste that back to the gen page, it gives me an error that those identifiers are unknown.
