944 Transmission Drive Axle Seals Replacement
Old 06-23-2011, 08:03 AM
massive
massive's Avatar
Default 944 Transmission Drive Axle Seals Replacement
Here's an easy tutorial I put together to cure an oil leak that was coming from the rear of the car. It centres around replacing the two drive shaft oil seals. Enjoy
massive is offline
Quick Reply: 944 Transmission Drive Axle Seals Replacement
