how do i add pictures and cars,etc. to my profile
Old 10-09-2003, 06:04 PM
porschefig
porschefig's Avatar
Default how do i add pictures and cars,etc. to my profile
hello,
the subject is basically my whole ?
i cant seem to figure out how to make it so a picuture and various other info appears when i post a forum or reply, ect.
i feel dumb. LoL
Old 10-09-2003, 06:56 PM
DonW-Cape Cod
R.I.P.
Lifetime Member
DonW-Cape Cod's Avatar
I believe you have to join Rennlist first. Then go to the FAQ in upper right corner...and follow the prompts.
Old 10-09-2003, 09:49 PM
DGlenn
DGlenn's Avatar
Here you go...
-Click on "my profile" in the top right corner.
-Click on "Edit Profile"
-At this point you can add some info into the Signature and Location fields (among others)
- Click "Submit Modifications" button to save.
- Click on "Edit Options" near the top
- Scroll to the bottom of this screen to change your avatar.
Hopefully that helps out.
Old 10-09-2003, 09:56 PM
peterjcb
peterjcb's Avatar
Also ...the maximun size for photos is 50kb. You may need to resize a picture before uploading it. There also seems to be a "bug" in the script because you cannot upload more that 1 photo at a time even though you can select more than 1.
Old 10-12-2003, 09:50 PM
porschefig
porschefig's Avatar
testing 1 2 3
Old 10-12-2003, 09:51 PM
porschefig
porschefig's Avatar
hmm..it still gotta figure out pictures
Old 10-12-2003, 10:14 PM
peterjcb
peterjcb's Avatar
Use the "Post Reply" button on the bottom right. Then click on the browse button in the "Attach File" field. You can then select a photo from your machine. Make sure that you adhere to the size limits. Try to upload a small sized photo like an avatar or something just to test out. Hope that helps you.
Old 10-26-2003, 09:19 PM
uptheorg
uptheorg's Avatar
I read that you have to have at least forty posts to change from the standard avatars to a custom one . . .
Old 11-18-2003, 06:19 PM
mrmuzak
5th Gear
mrmuzak's Avatar
Thanks for the tip!
David
Old 11-18-2003, 06:24 PM
mrmuzak
5th Gear
mrmuzak's Avatar
Oops, forgot to push the right button...
Old 11-27-2003, 01:23 AM
PWC
PWC's Avatar
How does one resize a photo?
Old 11-27-2003, 02:14 AM
DonW-Cape Cod
R.I.P.
Lifetime Member
If you're using the Rennlist Photo Gallery, you don't have to re-size when you upload to your gallery. This is true for some other galleries like Funcas and pay photo sites like fototime.
If you are re-sizing yourself I believe you need some software like Microsoft Picture it; ACDsee; Dell Photo Studio, etc.etc.
Old 12-01-2003, 04:59 PM
Jober
Jober's Avatar
Then i have to write....
Old 12-04-2003, 05:24 PM
I-Wana-951
I-Wana-951's Avatar
You can also use the qoutation buttoms to quote someone liek i am doing to u instead of retyping what they said.
do this but finding the post of the personu want to quote. IN the bottom right hand corner of their post, there is a set of qoutation marks. Clock those and post away!
keith
Old 12-05-2003, 04:54 AM
Jober
Jober's Avatar
OK! Thanx for the tip!!
/Johan
Quick Reply: how do i add pictures and cars,etc. to my profile
