Tuning / AFR Question
Hey all,
I'm running the Fabspeed GT420 kit on my 981 GT4. I had a few codes throw which they fixed for me quickly and I appreciate that support. I'm getting a persistent P0660 code, so I figured I'd datalog the car. I'm finding that the AFR is running fine during pulls themselves, but I'm getting some crazy values when I left off throttle. I don't know if these are actual concerns in the way that the data is being logged or whatnot, but they seem nuts to me in that I'm getting AFR readings as low as 10.88 but supposedly as high as 44.54. Feel free to see the datalog here: https://docs.google.com/spreadsheets...it?usp=sharing
You'll notice that the AFR goes wacky only on gear changes, and only if you're in gear and coasting off throttle, not under load. I am not a tuner nor do I profess to know the first thing about tuning, so I'm just curious what everyone's opinion is on this.
Reading now that the ECU may just shut injectors off to fuel conserve, which would make a ton of sense why there is no fuel in the ratio, but I figure I'll leave this here in case I'm wrong.
Don’t trust AFR readings with throttle body closed on decel/braking
while idling in neutral the AFR should not be wacky
That’s good. Car appears to be fine in neutral idling. Just reads what is probably max AFR with the throttle body closed due to the computer trying to calculate infinity haha. Appreciate the info. If nothing else, this tune runs a bit on the rich side under load and safe on idle, so the rest of the data says it’s very safe.
Yup the SDI DME shuts fuel off on coasting in gear, that's what you're seeing.....if you barely tip in to the throttle downhill next to the divider/wall you can hear the exhaust "pop" as fuel comes back in
Supercharged
Agree that this is a result of fuel being cut off on lift. What I don't agree with is the values. Atmosphere O2 levels are ~20%, so on lift you should see something in the lowish 20's not 30's and 40's. But under acceleration the values look to be spot on. On my supoercharged 928 I shoot for 12.5 under WOT at 5k+ RPM.
