Wing Support Seal - defect
hm yup, looks like additional screw points into the rocker panel to mount the side vents. Schnell on P9 posted the part: http://www.planet-9.com/981-cayman-b...tml#post971688
Could be a problem if there is no drain hole in the void of the rear hatch area where the wing is attached. I say this as a person who when through two months of agony trying to track down an interior leak in another car. I hate water!
You're welcome.
I was able to get the seal to lay down by applying pressure around the the seal-upright area, essentially pushing the seal down further around the upright. Time will tell.
I inspected two cars at the dealer yesterday and both appeared to be fine.
Maybe some assembly required?
Maybe some owners can lift up #3 before pushing it down and take a peek?
Here are some photos from my car. I haven't tried to remedy this yet. The flash makes it look worse than it probably is. Also, from most typical viewing angles, it's not as obvious. It's more obvious here due to the trunk being raised.
There are all different grades of double stick tape strength,
the VHB, Very High Bonding strength would be a suggestion
but if you ever attempted to removed it then extreme care is needed not to damage paint
