GT4 Alignment Limits?
#91
Yep - I mis spoke, I just did a little exercise and I don't see it impacting caster - the manifestation of the impact of caster yes, but not the caster measurement.
#92
Thanks both!
There are a few more motorsports-oriented shops around here that I'll call about this to see if they know how to do this and have shims on hand. I guess I should have done that in the first place, but they're all farther away and I just didn't think that I'd need anything extra to hit my alignment targets. If they don't have everything I'll need, then I'll definitely be pinging John @ BGB to get me sorted.
Compare that to individual shim pricing.
#93
#97
If you go to a lower offset wheel the caster is the same, however the outer edge of the tire will reach out further forward when turning the wheel. I believe this is what Shake was trying to get at.
#99
#103
Necroposting...
My owner's manual page 224 is consistent with images I can find on other threads. It shows:
OEM specs from the manual[/B]
Front camber: -1° 30' +/- 3'
Front toe-in (total): +2' +/- 2'
Rear camber: -1° 30'+/- 5'
Rear toe (per wheel): +10' +/- 2'[/B]
How did you do the degrees to inches conversion?
It seems my GT4 is limited to -1.3 deg front, -1.2 deg rear before toe limits. I'm really surprised the max limits are reached at the factory settings, and especially that the limits for camber are so low on a track-oriented car.
#104
Necroposting...
Your GT4's alignment limits are the lowest I've seen yet, though. Is your ride height maybe maxed out?
#105
So I’m pretty irritated. I can only get -1.2° on the left rear of my GT4 with stock parts while keeping 1/16” toe-in per side. I cannot add the toe arms due to rules of parking lot racing. Left can get all I need and more, but that does me no good. Ride heights are set to the publicized “lowest Porsche recommended”. I could lower, however much like my e92 m3’s rod bearings, the strut tower issues make me hesitant to go beyond those numbers. Nothing looks off underneath, subframe looks centered, etc. is this just quirky car crap that makes no sense or....
Any tricks here to get to at least the OE spec of -1.5°?
Thanks for any help!
