Xpel Headlight delamination issue
#136
So what exactly happens if you use XPEL on the headlights? My wife has a 2015 Boxster GTS and had the lights covered (this was before I read about the headlight issue) with XPEL. My SA had the headlights of his 2015 Cayman GTS covered as well. I brought this up to his attention and he said since he doesn't keep his cars very long, he wasn't worried about any delamination issues. As for my wife's car, I probably should not have had XPEL applied to the headlight. Since we're going to keep her car, I guess can't remove the film if it yellows or gets damaged, right? I am taking delivery of a Cayman GT4 shortly and plan to have it XPEL'd but will not have the headlights covered since I don't want to have any potential issues.
#137
If the shop installing the XPEL headlight film also offers Ceramic Pro 9H have them put Ceramic Pro on the headlight and cure it before installing the XPEL headlight film. This way if you have to remove/replace the XPEL film the film is stuck to the Ceramic Pro, which is protecting the UV coating.
#138
Second it's mostly to do with who is doing the removal and how are they doing it ie method
I did it on my GT 4 and the installer was confident that there would be no problem. If you don't mind your headlights looking like a galaxy then leave the uncovered
Congrats on getting a GT 4
#139
If you put film on and 6 years later they delaminate when you take it off you can have them re-coated. It's not ideal, but it is a solution.
If you don't get them coated and they get pitted from stone chips, well, its a new set of lights (or living with a set of lights that will never look 'A' grade again)
I don't track my car and stay well back from morons, so I have minimal risk and haven't covered them. If I tracked it I would absolutely have them covered.
#140
My car has one scuff (not quite a chip) on the left headlight. I have not tracked my car yet, but I do spend sometime in the canyons where there are plenty of little rocks to get tossed up.
However that is not where the "chip" came from. It literally happened while driving through my neighborhood, in first gear, at probably less than 10 mph. To add insult to injury it was literally while taking my car home for the first time from the Xpel installer, after just opting NOT to cover my headlights.
Worse yet there was literally no other moving cars, or even pedestrians within my field of view when it happened. A pebble seemed to have literally just come flying out of nowhere and hit my car. Maybe a bird dropped it from great height or something? I seriously don't know. But I saw it and heard it come at me at a pretty decent speed.
Point is, I wish I had covered my headlights, and I now recommend that anyone does. I didn't cover them out of concern for blemishing them 5 years from now when the film was removed. Instead they are ALREADY blemished.
My best hope is that when I do cover them, it hides that little scuff.
#141
As others have already said here and in other clear bra threads, you're really buying the installer, not the product. Find someone who earns your trust and consider their input when deciding what to do here. But note that some installers will not cover 991 or 981 headlamps as a matter of policy since they don't want to be on the hook for replacing expensive headlamps.
#142
Thanks all for your feedback. I was planning to do a ceramic coat so Jenner's comment was timely. I'll ask the installer about this approach since it sounds like the headlights get beat up whether tracked or just during normal everyday driving. When I get home this evening, I'm going to carefully inspect the headlights of all my cars since I've never noticed any chips or damage! That's what happens when you've got a blog site with such passionate members!
#143
#144
I was in the camp to not cover, but just put some yellow film on them from racelite designs. can see on IG zmon2086.
My reasoning was that in the case i want to remove the film to re apply or just have clear lights again and it peels some of the factory coating i can just buff the rest of the coating off and cover them in clear or yellow again. they will therefore always be protected......
#145
#146
My best home is that when I do cover them, it hides that little scuff.
It sounds like it was Murphy and his law that attacked you. Before I got PPF installed rocks would literally bounce from the other side of the highway and ping off of my car. After I had it covered I could pretty much tailgate a dumpster without getting anything on my car. Weird world.
I am all for people covering headlights as I explained, but I'll personally take the risk for now.
BTW your scuff is almost certainly treatable by a good detailer. Does it temporarily 'disappear' if you cover it in water? It's likely just a blemish in the coating.
#148
In Your Face, Ace
I'm a shop owner and Xpel installer.
We do the 981/991 headlights on a regular basis without issue. One technique we use to make sure De-lamination doesn't occur, is to lightly heat the film with a steamer while we are installing it on headlights and even more so if we are removing the film from a headlight. We've never had any issues.
We had a customer with a 991 that removed some Lamin-X film that pealed the coating off, so we wet sanded the rest off, polished them out and installed the Xpel. They looked like new afterwards.
There really shouldn't be a problem doing the headlights in Xpel, and with a little steam removing the film is not a problem either.
#149
In Your Face, Ace
The blue tape isn't able to absorb and disperse the energy from impact, so damage still occurs. Not to mention the tape comes unstuck, accumulates dirt and then scratches whilst flapping at 100mph. Not a very comprehensive solution.
#150
I'm a Big fan of Young Frankenstein !!
