Sponsored by: APR
Sway bar setting
Old 04-18-2016, 05:29 PM
Jasonanv
Jasonanv's Avatar
Default Sway bar setting
I'm gonna change my sway bar setting. Should I do soft front medium rear or medium front hard rear? Has anyone tried soft front hard rear?
Old 04-18-2016, 05:49 PM
jphughan
jphughan's Avatar
Plenty have done soft front and hard rear since that's the least understeer-y setup (all else being equal), but some have gone back to medium on the front in an effort to preserve the outsides of their front tires. Can't comment on the other setups you mentioned. I'm leaving my adjustable bits alone (except for an alignment) until I properly learn to drive what I have.
Old 04-18-2016, 06:10 PM
matttheboatman
matttheboatman's Avatar
I suggest an initial set up of full aero, soft front, and leave the rear in middle. Then, as you progress and gain more control of the car, change the rear to full hard to help rotate the car during turn in.
Ultimately, the car has a natural understeer due in part to the smaller tires up front. But, the car responds very well to throttle input particularly in 2nd gear allowing you to manage the understeer with throttle inputs.
Kdawg86 (07-27-2020)
Old 04-18-2016, 06:17 PM
James88
James88's Avatar
Haven't got my car yet, how are these set up from factory, med front and rear?
Old 04-18-2016, 06:26 PM
Yomi
Yomi's Avatar
I was thinking S/M but then decided to do M/H at the suggestion of a couple other posters. I've done two autocross days with that, and am happy. However I didn't try other settings on the same day, so that isn't scientific. Ideally I'd get an alignment and other changes done, have more time with the car, take it to a test and tune and try different settings. Even then it would answer what was best for me doing autocross, while you doing some other activity with different alignment and tires / pressures may like something different.
Add: factory is middle setting for both front and rear.
Old 04-18-2016, 06:39 PM
kyrocks
kyrocks's Avatar
I have front soft and rear hard.
Old 04-18-2016, 06:41 PM
GrantG
GrantG's Avatar
Received 4,743 Likes on 2,703 Posts
Me too and if there was an even harder 4th setting in rear, I'd be tempted to try it.
Old 04-18-2016, 06:55 PM
jphughan
jphughan's Avatar
Yes. Aero is in the less aggressive setup, and ride height seems to be nearly maxed out, though not entirely, potentially due to a target rake or corner balance. I was surprised how close to perfectly corner balanced my car was when I took it in for an alignment and corner balancing.
Old 04-18-2016, 10:15 PM
katmeho
katmeho's Avatar
Whenever you make a bar change, be sure to go back after a session or two and tighten up the end bolts. A couple of us have had them loosen up after making adjustments.
Old 04-19-2016, 11:54 PM
kyrocks
kyrocks's Avatar
Yep. Experienced this twice.
Old 04-23-2016, 09:53 AM
needmoregarage
needmoregarage's Avatar
Received 1,330 Likes on 570 Posts
I spoke to my service manager about this. He said the bolts are designed for single use, and should not be re-used once removed. This is why they are loosening up after adjustment.
Old 04-23-2016, 10:00 AM
myBailey07
myBailey07's Avatar
Makes no sense to me..."Let's put an adjustable sway bar on the car, but add a single use bolt to adjust this bar..."hmmmm....
Rodolphe GT4 (12-17-2022)
Old 04-23-2016, 10:46 AM
needmoregarage
I see your point but I'm just passing along what he told me. Since feedback indicates the bolts must be significantly over torqued with lock tite applied, or they come loose .... I would question whether they should be re-used. But I agree: to put a single use bolt in an adjustable sway bar doesn't seem to add up.
Old 04-23-2016, 11:31 AM
ExMB
ExMB's Avatar
Received 1,328 Likes on 808 Posts
The only way this would make sense to me is if they are coated with blue loctite or equivalent. Otherwise I have to refer back to what we already know from posts on here; the membership is usually better informed than the employees.
Old 04-23-2016, 03:46 PM
24Chromium
24Chromium's Avatar
The fasteners loosen up when you move them onto a painted section of the bar. In other words, the paint gets rubbed off, and a minute gap forms. Hence they need to be tightened again.
Quick Reply: Sway bar setting
