New Launch - Rollbar for GT4 by CompetitionMotorsport
NEW!
COMPETITION MOTORSPORT is proud to announce our CMS Performance Roll Bar line of premium bolt-in roll bars for the Porsche 981 Cayman (including the GT4).
CMS PERFORMANCE BOLT-IN ROLL BAR FOR THE PORSCHE 981 Cayman (all models including GT4)
Introductory Special Deal: $2,295 including shipping and powder coating in the color of your choice for the first 10 orders! Order Here
-Industry leading 1.75″ X .120" 4130 chrome-moly steel roll bar main hoop, diagonal braces, and rear kickers for superior strength
-Meets or exceeds PCA, SCCA, and NASA TT rule requirements
-One-piece main hoop and one-piece rear kicker
-No cutting of the center carpeted "hump" to preserve oem carpet and trim
-Precision-machined mounting plates
-TIG-welded in the USA by a master welder using American CrMo steel
-CNC machined high-strength-steel interlocking clamps to ease installation
-Allows full seat travel with any seat
-Easy to install and perfect fitment, guaranteed
-Comes with detailed installation instructions, all necessary hardware and trimming templates
Competition Motorsport is proud to introduce the CMS Performance Roll Bar, the strongest and safest bolt-in roll bar on the market for your Porsche 981 Cayman (base, S, GTS, and GT4). In designing our roll bar, safety and structural rigidity were our primary goals. That's why we use thicker 1.75" x .120" wall 4130 CrMo tubing, which meets or exceeds PCA, SCCA, and NASA requirements for Time Trial racing (wheel-to-wheel racing requires a full cage).
The harness bars are designed to place harness shoulder straps at the proper angle (0° to -20°) to the driver, regardless of seat position, without cutting the center carpeted "hump". This design also provides an ideal mount for a Smarty Cam! Our use of thicker CrMo tubing throughout allowed us to keep the driver's rear view unobstructed by rear diagonal braces. This also allows unfettered access to the engine cover with the roll bar in place.
The rear kickers bolt to the rear shock towers, providing the safest possible mounting point. This adds tremendous rigidity to the rear chassis and suspension. The main roll hoop is mounted to the frame structure across the rear bulkhead.
Fully TIG welded by a master welder, the integrity, fit, and finish of the Competition Motorsport roll bar is unsurpassed. We offer a full range of powder-coat colors to match your Porsche, or satin black for a more stealth appearance.
Our sale price includes shipping (in the contiguous U.S.) and powder coating any color you like.
I like the design with no carpet cutting!
What does it weigh?
Can you take a picture or measure the gap between the lateral harness bar and the firewall? It looks like a larger gap than others, which may limit how far the seat can go back. Might just be the angle of the pic
Also, can you elaborate on the rear bolting direct to the shock towers? Is this different than the other bars?
Thanks!
Matt
What does it weigh?
Thanks!
Matt
Unless you are short in height (in which case the oem sport bucket isn't the correct seat for you anyway), the CMS bar maintains the correct harness angle as prescribed by the harness manufacturers.
Looks great! Good job on the placement of the harness bar and unobstructed rear view as well as no carpet cutting. I have a GMG bar in my GT4 but the harness bar is high. I like the product but there is no denying the harnesses go upwards to the bar even with the seat as high as I can get it.
Each of the attachment points will require trimming of the plastic pieces. We offer templates for you to cut your existing pieces or can offer you additional oem interior trim pieces precut (at an additional charge) so you can retain your oem pieces.
Thank you John
Thank you Etrain
