How to restore a Sherman tank - a pictoral
Old 03-09-2008, 07:27 PM
  #61
89magic98
In the Sink
89magic98's Avatar
OK, I'll ask a question or three.....
Looks like some parts are more rust than metal. what are you using to remove the old rust/paint? Aside from primer, are you doing anything to prevent the rust from coming back (some sort of chemical rust preventative treatment). Are most surfaces getting the rattle-can treatment, or do some things get powder coated or painted with something more durable (like spots that someone would stand/climb on)?
Looks good!
89magic98 is offline
  #62
H2
H2's Avatar
If you hadn't posted verification fotos of the tank resto, I don't think I'd have believed this. I'd have kissed that tank off as un-restorable....and a total night-mare to try and get back into shape. Very impressive work. It's certainly proof that anything can be restored. What a challenging job. Congratulations. Thanks for posting. Great work. If it ends up in a museum, I might go see it sometime.
Harvey
H2 is offline
Old 03-09-2008, 07:52 PM
  #63
sharky47
Set to Full-Auto
sharky47's Avatar
I will continue with the pictures in a little while.
Yes, this is Sherman restoration #2 - the first one was in great shape, but was in Israeli trim - we did a light re-restoration to bring it back to American spec.
This one in the pictures was a COMPLETE resto - it was in BAD shape when it came in.
sharky47 is offline
Old 03-09-2008, 08:42 PM
  #64
sharky47
Set to Full-Auto
sharky47's Avatar
sharky47 is offline
Old 03-09-2008, 08:46 PM
  #65
sharky47
Set to Full-Auto
sharky47's Avatar
sharky47 is offline
Old 03-09-2008, 08:51 PM
  #66
sharky47
Set to Full-Auto
sharky47's Avatar
sharky47 is offline
Old 03-09-2008, 08:54 PM
  #67
mglobe
The Penguin King
mglobe's Avatar
That's freaking awesome. You should bring it to a PCA concours event.
mglobe is offline
Old 03-09-2008, 09:07 PM
  #68
stumpjumper
stumpjumper's Avatar
this is simply amazing work, the details, the sheer size of the "little" things like that cotter pin, it's awesome
stumpjumper is offline
Old 03-09-2008, 11:08 PM
  #69
sharky47
Set to Full-Auto
sharky47's Avatar
sharky47 is offline
  #70
richard glickel
richard glickel's Avatar
Nah, Daniel would have to bring a restored schwimwagen or one of those giant Porsche tanks to cop a trophy at a PCA event.
Richard
richard glickel is offline
Old 03-09-2008, 11:18 PM
  #71
sharky47
Set to Full-Auto
sharky47's Avatar
sharky47 is offline
Old 03-09-2008, 11:31 PM
  #72
sharky47
Set to Full-Auto
sharky47's Avatar
sharky47 is offline
Old 03-09-2008, 11:40 PM
  #73
sharky47
Set to Full-Auto
sharky47's Avatar
sharky47 is offline
Old 03-09-2008, 11:50 PM
  #74
graham_mitchell
graham_mitchell's Avatar
Truly impressive, Daniel!
Would it be rude to ask how much the total restoration cost is? I have a figure in mind and am just curious. (PM me if you prefer). I assume that if you are in the business then it doesn't hurt to make this public.
I see that you are machining some parts from scratch based on rotted out old parts. What did you do with the many rust craters in the body? Cut sections out and weld in new steel?
Thanks for posting!
graham_mitchell is offline
Old 03-10-2008, 12:37 AM
  #75
sharky47
Set to Full-Auto
sharky47's Avatar
I am not privy to the total costs - the labor FAR outweighs even the high parts cost, I do know that!
The hull was in pretty good shape, the pitting does not matter that much - but the big chunks where either filled in with weld or body putty. The preforated steel plate in front of the driver was done by the wrecking company to make a window that was still armored. We removed that and welded in steel plate to fill in the hole.
sharky47 is offline
Quick Reply: How to restore a Sherman tank - a pictoral
