Mark this thread as Unsold
Adaptec Speedware - The Finest Wheel Adapters, Wheel Spacers and Hub Rings.
#108
#112
How much would it be for a pair of 5mm spacers in 5x130 but with 20mm wide bolt holes? I have to measure for the hub centric opening but would be just a flat spacer with no wheel hub centricity
#113
you are looking for just a flat spacer? do you mean the lug holes need to be opened up to 20mm instead of the standard 14mm? if so send me a PM
#119
Thought I had posted this before, but do not see it now...... Do you guys offer a 3mm spacer for Porsche wheels? Standard 5x130mm bolt pattern, but would need to be flat (no raised areas) so that it would fit on a 2001 GT3 Cup using the center lock nut. Thanks.
#120
Yes we can. $70 for the pair on those. Pm for details or call 775.351.1000. Thanks
