Parts Marketplace - Old A place for Rennlist Members & Sponsors to sell new & used Porsche parts.
Mark this thread as Unsold
Parts Search
Keyword:
Category:
Price (no $ sign please):
Private or Vendor Listing:
Location (Region):
Item Condition:
Cars Search
Keyword:
Year:
(Range)
Make:
Model:
Cont. Porsche Models:
Mileage (numbers only please):
Color:
Private or Dealer Listing:
Location (Region):
Transmission Type:
FS: Running 951 engine (motivated seller)
Old 05-22-2016, 11:30 AM
ausgeflippt951
ausgeflippt951's Avatar
Default FS: Running 951 engine (motivated seller)
Category: Engine - Complete
Price (no $ sign please): $1500
Private or Vendor Listing: Private Listing
Part fits (select ONLY those which apply): 924/931/944/951/968
Location (Region): NorthEast
Item Condition: Used
Used 951 engine out of my 1986 944 Turbo. Engine was an excellent runner before pulling it (to drop in LS2). I have replaced the aftermarket turbo with a stock K26/6 in decent shape.
The long-and-short of it is that the engine runs very well but has a few oil leaks. Compression for cylinders 1-4 is: 145psi, 143psi, 142psi, 133psi, respectively.
Note: stock injectors not included. Can include 70# injectors if you like.
$1500 OBO. Motivated seller, as I'd really rather not move with this. Preference (and discount) given to local buyer (Washington DC area).
Basic engine stats:
  1. 130k miles on bottom end
  2. 30k miles on:
    Ported head
    5-angle valve job
    New HG
  3. Car has averaged 50% track, 50% street for the past 7 years.
  4. Always run with dual oil coolers (max temp reached was ~230F)
  5. Blackstone oil analysis after every oil change (will be providing most recent report once I get around to sending the oil out for analysis)
  6. Oil changes twice/year
  7. Never driven on-boost until oil reached >150F.
  8. Max boost: 1.05 bar (with different turbo than is coming with the engine)
  9. EGTs never above 1500F
  10. Compression check done Sept 2015:
    Cyl 1: 145psi
    Cyl 2: 143psi
    Cyl 3: 142psi
    Cyl 4: 133psi
  11. Burned very little oil (for these motors) with the Vitesse turbo. Typically ~0.5qt per DE day (three or four sessions).
  12. K26/6 turbo has slight shaft play and burned a slight amount of oil before removal (more than the Vitesse) but still well within spec. This turbo was removed from a previous (stock) 951 I owned before this one.
  13. Water pump done during 2014 season.
  14. Belts and rollers done prior to the 2015 season.
  15. 70lb injectors: Cleaned annually
  16. AFR: ~11.1-11.3:1. Note that optimum power comes at around 11.7 but I wanted a bit more cooling + protection so purposefully was a little rich.
  17. Current oil leaks:
    Note: weeps all the time but actively leaks only when motor is warm. After shut-off, drops 2-3 drops typically.
    Most substantial leak: lower turbo O-ring.
    Weepage around oil pan
ausgeflippt951 is offline
Old 05-26-2016, 05:08 AM
shortyboy
shortyboy's Avatar
Is the Vitesse turbo up for sale?
shortyboy is offline
Old 05-27-2016, 06:47 PM
ausgeflippt951
Hi, unfortunately no. The turbo was sold separately.
Quick Reply: FS: Running 951 engine (motivated seller)
