classifieds |
membership |
rennlist |
photo album     sponsors | upload photo | chat | marketplace     |
| Register | FAQ | Calendar | Search | Today's Posts | Mark Forums Read | Dealer Listings | My Recent Topics | Vendor Directory |
Thread Tools |
#1 |
Moderator
Rennlist Member |
I thought this might be useful. Post the information related to your repairs warranty or otherwise and I will keep it at the top for quick reference.
No discussion just facts please, I will remove discussion posts, take them into a new thread. Thanks.
Michael Mudditt Cayenne S, Titanium Metalic / Black, PCM Air, BMC Air Filters, FabSpeed Cat Bypass Pipes and Dual Tips. MoBridge iPod / Sirius and BT gallery |
#2 |
Moderator
Rennlist Member |
Here is my list, this is a list of the new parts fitted, the fault finding processes and faults found would take to much time.
DME Control Unit - (4 or 5) Towing Control Unit - (3) Plug and Coils - (all) Coils - (1) A/C Servo units, lower dash - (3) Carden Shaft - (1) Transmission - (1) Comfort Control Unit - (2) Parking sensors (2) There is more i will have to dig out my records.
#3 |
User
accessory belt 12k (took several weeks to get)
weatherstrip on sunroof 19k rear door sunshade 19k transmission 19k (not fixed) transmission 32k (not fixed) transmission 35k (not fixed) transmission 37k (not fixed) transmission 42k (not fixed) PHC unavailable 42k (not fixed) PCM failure 45k (not yet taken in, vehicle is in lemmon law process) squeeks and loose trim too numerous to mention..... DT |
#4 |
Moderator
Rennlist Member |
PSM FAILURE WORKSHOP
AIR SUSPENSION FAILURE WORKSHOP Diagnosed to a steering angle sensor. lets see when I get it back.
#5 |
Rennlist Member Join Date: Dec 2003
04 Turbo (8/03) build
PCM Failure- fixed (1) warranty Key Range poor - New fobs now can open doors from 40yds. - fixed (1)warranty Power steering Pump leak -fixed (1) warranty Allignment Off - fixed after second time but paid for Rear hatch Shocks didn't support hatch- fixed-warranty Dead battery.....recharged for $50 Front Brake caliper paint around Bleed valve peeling- fixed with new front calipers -warranty Coil pack pencils all replaced w/ spark plugs which were all fouled out- fixed -warranty. All this with under 12k
04 Cayenne Turbo 87 Carrera Cab |
#6 |
Moderator
Rennlist Member |
Came out of the office at lunchtime and thought my looked really good except it was actually down on its stops.
I started up and it pumped itself back up, no error message. Tonight I got the the Air Suspension Fault - Workshop Back to the dealer So much for the steering angle sensor they fixed 2 weeks ago
#7 |
Moderator
Rennlist Member |
Replaced Air Compressor 1 955-358-901-01, 2 days in shop Warranty phew !! I wonder how much that would have cost.
#8 |
Rennlist Member Join Date: Oct 2003
2005 Cayenne
15 months old Zero warranty claims. 2 open recalls performed (glass latch replace, reprogram rear gate latch) |
#9 |
User
04 CTT, 29k miles
8 Coils Replaced TPMS Not Working - Cleaned Connection at Control Unit & Reprogrammed Air Bag Fault Code 1217 - Repaired Per TSB Driver's Side Seat Belt Does Not Retract - Part Ordered Passenger Side Rear Window Does Not Work - Part Ordered Michael 04 CTT 92 S4 RS2 |
#10 |
User
Location: Tucson, AZ--'06 Cayenne, '03 325CiC, '98 318tiCK
'06 V6
Passenger side door entry plastic (warped) Transmission control unit (after major failure and 125 mile tow)--moderate improvement Transmission valve body--no effect Transmission--stay tuned... |
#11 |
User
06 (0506) CS
- modification kit for lenses |
#12 |
Rennlist Member Join Date: Mar 2003
03 Cayenne S 37K Miles
1. Rear Window Washer Nozzle 2. Gas Gauge Sensor 3. TSB Trim Replacement 4. All Other TSBs
Cay-Ute 2003 Cayenne S - Lapis Blue (Gone to CPO) 2003 Carrera 4 Cabriolet - Triple Black 2008 CTT - Basalt Black. Chestnut Leather Arrived 4/25/07 |
#13 |
Moderator
Rennlist Member |
Here we go again
Started up this morning, my 8 s now a 4 AGAIN Same as previous, engine will run but throwing pure gas out the back on one side. Typical pencil coil shuddering. Wonderfull ! Dealer, sales dept were open and got me a loaner. ugh
#14 |
Moderator
Rennlist Member |
OK another coil went, this time it also killed a "cam sensor" on order for tomorrow.
ugh !
| Tags |
| 1217, 2006, carden, cayenne, coils, failure, fault, leak, pcm, pencil, phc, porsche, shaft, suspension, unavailable, warranty, workshop |
| Thread Tools | |
