classifieds |
membership |
rennlist |
photo album     sponsors | upload photo | chat | marketplace     |
| Register | FAQ | Calendar | Search | Today's Posts | Mark Forums Read | Used Cars | My Recent Topics | Vendor Directory |
Thread Tools |
#16 | |
Rennlist Member Join Date: Oct 2007
Quote:
2004 CS Gone but loved 2002 MB 430 CLK Cab 1997 MB E320 (bulletproof) Gone and hated 2005 FX 45 |
#17 |
UPDATE: Had the coils replaced and now I no longer have the Oil Monitoring System Failure. Interesting side effect. Diagnosed originally as faulty sending unit, but indy said before he replaces it, drive it after coils were fixed and see what happens. So far, so good.
#18 |
Rennlist Member Join Date: Jan 2005
Jim _____________________ 1997 C4S Metalic Black 2005 Cayenne S Titanium Metalic - on it's 2nd engine... 1998 Toyota Tacoma 4WD - 2x4, dog and mulch hauler |
#19 |
Rennlist Member Join Date: Jun 2004
Got the same warning last week and oil level is fine. Haven't tried the "tapping" thing. Wonder if it will be covered under extended warranty?
'03- Cayenne TT '08-Toyota Highlander '08-Toyota Sienna LE |
#20 |
Update: Turns out they will need to replace the instrument cluster as well...that's a 3k+ fix that is covered under my extended warranty...also getting the cardan shaft replaced
#21 |
Rennlist Member Join Date: Nov 2007
Before you run out and have your instrument panel replaced, I'd recommend having your coils replaced. That is, if you're still using the original coils. Several of us that had this fault had the ignition coils replaced and the fault disappeared. In addition, increased power and performance.
#22 | |
Quote:
#23 |
Rennlist Member Join Date: Jan 2004
I had my inst. cluster replaced 2 times because the trip odometer wouldn't reset. Wasn't a big issue but since it was under warranty I had it done. 1st replacement worked for about a week so I waited a couple of mos. and had it done again. 2nd replacement has been working fine for about 4 mos.
After the 2nd replacement my service writer said they had just started seeing a problem with these things. Glad to know I saved myself 3k x 2 with the warranty. I think I'm on my CPO 2 yr. warr. now, have to check.
Bill '97 993 C2 Coupe, Arena Red/Black '06 Carmon Red Pepper "S" '97 BMW M3/4/5 '97 Arena Red/Gray 993 Cab (sold) '93 968 Coupe (sold) |
| Tags |
| 2001, 944, 997, audi, check, failure, level, location, monitoring, oil, porsche, s4, sending, turbo, unit |
| Thread Tools | |
