Rennlist Discussion Forums   classifieds | membership | rennlist | photo album
sponsors | upload photo | chat
Go Back   Rennlist Discussion Forums > Water Cooled Technical Discussion Areas > Porsche Cayenne Forum
Sign in using an external account
Register Forgot Password?
Search
Thread Tools Search this Thread
Old 05-22-2009, 12:25 AM   #1
Dennis C
A Texan in the Mountains
Dennis C's Avatar
Dennis Cassell Texanhoosier
Default Check engine light... no warnings
Well, the CEL came on today. No warning. Nothing unusual, car running fine. Not sure what to make of it. I dropped it off at the dealer this afternoon.
Hopefully it won't be anything major. This is my first trip to the dealer since my factory warranty expired. I do have an extended warranty, and I was happy to see that the dealer pulled it up in their computer and is prepared to use it if necessary.
I've got my fingers crossed that it is nothing major. I'm wondering if it is coils. Mine are still the originals at roughly 52,000 miles. The car sometimes idles a little rough, but that's about it.
We'll see!
To remove this ad, register today or login if you already are registered!
Dennis
Porsche Cayenne S
Porsche Carrera 4S
Dennis C is offline   Reply With Quote
Old 05-22-2009, 01:06 AM   #2
ltc
Super Moderator
Needs More Cowbell
gas cap?
ltc is offline   Reply With Quote
Old 05-22-2009, 02:26 AM   #3
bigbuzuki
User
bigbuzuki's Avatar
bigbuzuki is offline   Reply With Quote
Old 05-22-2009, 08:13 AM   #4
Dennis C
Dennis C's Avatar
I didn't think about the gas cap. My wife has been using the Cayenne as her daily driver since I bought the 911. It's certainly a possibility. I'll feel quite foolish if that's all it is... but it won't be the first time (or the last time) I've felt foolish.
Dennis
Porsche Cayenne S
Porsche Carrera 4S
Old 05-22-2009, 09:50 AM   #5
Dennis C
Dennis C's Avatar
Quote:
Originally Posted by ltc View Post
gas cap?
Just heard from the dealer. There were two codes in the system. One was... yes... the gas cap.
The second one was a cam adjuster fault. According to the tech, this can happen when the oil gets a little dirty and/or starts to break down, usually when an oil change is needed. The oil change light has not yet come on for this vehicle, I was planning to have it changed at the 60K mile service. Looks like I'm getting it changed today!
Should be ready this afternoon.
Dennis
Porsche Cayenne S
Porsche Carrera 4S
Old 05-22-2009, 09:59 AM   #6
OCNYPORSCHE
OCNYPORSCHE's Avatar
Most likely Cayenne withdrawal Too much 996.
2012 958 Cayenne Turbo
2011 970 Panamera Turbo
2004 996TT Cabriolet
1980 911SC Targa
Gone: 2006 997 Carrera S, 1999 996 C2 Cabriolet, 2008 957 Cayenne S, 2005 955 Cayenne Turbo, 2012 958 Cayenne S, 2013 958 Cayenne Diesel
OCNYPORSCHE is offline   Reply With Quote
Old 05-22-2009, 10:02 AM   #7
Dennis C
Dennis C's Avatar
I'm sure that's it!
I'm actually changing the oil myself on the 996 this weekend. I haven't worked on it yet, so I'm looking forward to that.
Dennis
Porsche Cayenne S
Porsche Carrera 4S
Old 05-22-2009, 10:23 AM   #8
OCNYPORSCHE
Quote:
Originally Posted by Dennis C View Post
I'm sure that's it!
It is alot easier. There is no stupid plastic cover with 18 screws to remove. That plastic cover on the Cayenne takes all the time. I even changed the 996 oil without jacking or driving it onto 2x12s. It is possible.
1980 911SC Targa
Old 05-22-2009, 11:19 AM   #9
ltc
Super Moderator
Needs More Cowbell
Just heard from the dealer. There were two codes in the system. One was... yes... the gas cap..
Larry taught me well.
Old 05-22-2009, 11:36 AM   #10
Dennis C
Dennis C's Avatar
I never doubted you...
I've had a discussion with Mrs. C this morning about the need to properly tighten the gas cap. I'm not sure if she really listened, or if she thinks I'm full of crap. Doesn't matter much either way, I suppose.
Dennis
Porsche Cayenne S
Porsche Carrera 4S
Old 05-22-2009, 11:41 AM   #11
ltc
Super Moderator
Needs More Cowbell
It may actually be a failing seal on the gas cap, not improper tightening/installation after refueling.
Old 05-22-2009, 01:08 PM   #12
Dennis C
Dennis C's Avatar
Possibly... we'll see if it happens again.
Dennis
Porsche Cayenne S
Porsche Carrera 4S
Old 05-23-2009, 02:36 AM   #13
porsche52
Board Certified Porsche Trauma Surgeon
Cayenne Grief Counselor
porsche52's Avatar
If you are 100% shure the gas cap is tight, and the system passes a short test (via PIWIS) I would suggest installing a new tank vent valve, they can get debri in them and cause an evap leak (CEL). Did the dealer tell you if it was a very small, small, or large leak? Loose gas cap=large leak. Intermittant faulty tank vent valve=very small to small leak. If the tank vent valve is stuck wide open, then you will get a large leak and possible hard starting engine. It can be a royal pain in the butt diagnosing this evap crap!!
porsche52 is offline   Reply With Quote
Old 05-23-2009, 10:07 AM   #14
Dennis C
Dennis C's Avatar
The dealer didn't mention the size of the leak. So far, we've reset it and tightened the cap and everything seems fine.
Dennis
Porsche Cayenne S
Porsche Carrera 4S
Old 05-23-2009, 10:24 AM   #15
ltc
Super Moderator
Needs More Cowbell
I wouldn't be surprised if 'Porsche52' had 'Pig Whisperer' placed above his avatar instead of 'Addict' in the not too distant future....
Paid Advertisement
Tags
996, cap, cayenne, check, control, emission, engine, evap, gas, leak, light, loose, porsche, tank, warning, yukon
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2014, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.5.2
Copyright ę 1998 - 2007 Rennlist.com
Advertise on Rennlist - Privacy Statement - Terms of Service - Jobs
Emails & Contact Details
