classifieds |
membership |
rennlist |
photo album     sponsors | upload photo | chat | marketplace     |
| Register | FAQ | Calendar | Search | Today's Posts | Mark Forums Read | Dealer Listings | My Recent Topics | Vendor Directory |
Thread Tools |
#1 |
Pig Whisperer
Cayenne Grief Counselor Rennlist Member Join Date: Dec 2008
1.The pig pre op. Cayenne S.
2. upper pipes with thermostate housing 3. " " " " 4. Lower pipe. 5.Crack in lower pipe, outlined with grey sharpie. 6. " " " " " 7. After cutting lower pipe and removing majority of it. Rear console 8. Lower pipe @ engine block. Old pipe bits still installed. 9.Billet insert with o-rings. 10. Billet insert installed in rear console 11. New 2 piece lower pipe installed. 12.Close up of 2 piece connection, rubber hose connecting pipe to billet insert. 13.New lower pipe @ engine block connection. 14. New upper pipes, cast, one piece of alloy. 15. New lower and upper pipes installed, with new black plastic bleed lines. Intake can now go back on. |
#2 |
Moderator
Rennlist Member |
Great input, I will stick as it applies to so many people
Michael Mudditt Cayenne S, Titanium Metalic / Black, PCM Air, BMC Air Filters, FabSpeed Cat Bypass Pipes and Dual Tips. MoBridge iPod / Sirius and BT gallery |
#3 |
Rennlist Member Join Date: Jan 2004
Wow, outstanding! Thank you for documenting this.
Bill W. '06 Carmon Red Pepper "S" '97 BMW M3/4/5 '97 Arena Red/Gray 993 Cab (sold) '93 968 Coupe (sold) |
#4 |
User
Got the part numbers for the fix?
#5 |
Super Moderator
I still chuckle everytime I look where the starter ended up...under the plastic tube carrying water/antifreeze...I'm sure they had a good reason.
...Lewis |
#6 |
User
I would like to have been a fly on the wall in the boardroom when the engine plans were approved.
"Ja, ja very gut , Fritz. ve put zee sharter in zee meedle of zee engine so nobody sees it. Then vee vill run coolant lines, plastic, ja ja, plastic over zem. Ve make changing zee shtarter a 12 hour yob. You gonna tell me there was not one engineer there that had any problem with all of this? |
#7 |
Rennlist Member Join Date: Dec 2003
Here's a copy of my invoice, Porsche52 or anyone else is welcome to add whatever is missing to this list for the DIY'er.
The job took the mech only one day, I advise to bring your car in the day before so everything is cold when they work on it. I had no problems with the car, we just did it voluntarily ![]() The total was $1607.33 from my local Porsche dealer.
04 Cayenne Turbo 87 Carrera Cab |
#8 |
Curious why those are mostly 948 part numbers and not 955 part numbers?
Thanks for the info Vino. Actually I would have expected a bigger invoice. Glad for you it wasn't.
#9 | |
Just call me Pops
Rennlist Member |
Quote:
#10 |
A Texan Hoosier
Rennlist Member Join Date: Aug 2007
When did Porsche stop putting in the plastic coolant pipes? I assume that my 2004 has the plastic pipes, but it was a late build car in the cycle. Is it possible that they aren't plastic pipes? Is it possible to check by VIN? I'm sure this has been asked before, but I couldn't find it...
Dennis 2004 Porsche Cayenne S 2002 Porsche Carrera 4S 1995 Volvo 850 GLT PCA Member |
#11 |
Super Moderator
You've got plastic.
...Lewis |
#12 |
Yes, but when did they stop using the plastic? A very valid question.
#13 | |
Quote:
#14 |
A Texan Hoosier
Figured I did... I was just curious on the timing of the change.
#15 |
Pig Whisperer
To my knowledge, I do not believe they ever bulit engines from the factory with the metal pipes installed. We did a re-man engine a while back, it had plastic pipes, we converted it prior to installing it. Hell, the 2nd gen 9PA has a plastic coolant pipe under intake, there is only 1, but its plastic! The 2nd gen 997 (9A1) motor has platic pipes all over the place!!
| Tags |
| attaches, cayenne, coolant, engine, intake, line, manifold, picture, piece, pipe, pipes, porsche, tube, tubes, water |
| Thread Tools | |
