Rennlist Discussion Forums   classifieds | membership | rennlist | photo album
sponsors | upload photo | chat | marketplace
Go Back   Rennlist Discussion Forums > Water Cooled Technical Discussion Areas > Porsche Cayenne Forum
Old 11-05-2009, 04:59 PM   #1
immacul8cs
User
Default brake pad light comes on
during the last brake service i replace all 4 rotors and all the pads----that was appx 8 months ago----now the warning is back on----
how can i tell if the rear also need doing---is it true that front pads get worn out twice as fast then rear pads----
immacul8cs is offline   Reply With Quote
Old 11-05-2009, 05:22 PM   #2
ltc
Super Moderator
(training wheels attached)
ltc's Avatar
Front brakes wear quicker than rears, simply based on bias and weight distribution.
...Lewis
ltc is online now   Reply With Quote
Old 11-05-2009, 05:45 PM   #3
immacul8cs
User
thank you--how to tell---are the rear pads little thinner than front pads to start off with----
Old 11-05-2009, 07:27 PM   #4
Renn 951
Renn 951's Avatar
Quote:
Just eyeball 'em. You don't need a warning light to tell you whether there is any pad material left. It's hard to see how you could have worn them down in only 8 months - how many miles have you put on during those 8 months?
88 951
07 Boxster S
04 Cayenne S
06 BMW 530xiT
00 Audi S4 (sold)
Renn 951 is offline   Reply With Quote
Old 11-05-2009, 10:14 PM   #5
immacul8cs
User
Quote:
---could it be a damaged sensor----i have put on 20k miles on the pads
Old 11-05-2009, 11:00 PM   #6
Renn 951
Renn 951's Avatar
I had over 50K miles on my C-S before the front wear sensor triggered. I changed my rear pads at over 71K miles and the wear sensors hadn't even triggered yet.
20K miles in 8 months is a lot of miles, but I'd be surprised if you've worn out pads in that time unless you've got a caliper issue causing the pads to drag - and you'd probably hear something if that was the case. Check the wiring for your pad sensors and see if any of them have broken.
88 951
07 Boxster S
04 Cayenne S
06 BMW 530xiT
00 Audi S4 (sold)
Old 11-06-2009, 10:55 AM   #7
immacul8cs
User
front wons are definately worn--possibly it was the drilled rotors that are eating the pads---i am putting hawk at front to see if they last a little longer
Tags
06, 997, audi, brake, cayenne, check, gt3, light, needed, pad, porsche, s4, sensors, warning, wear, worn
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin®
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.2.0
Copyright © 1998 - 2007, Rennlist.com
Advertise on Rennlist - Terms of Service - Privacy Policy - Jobs
