Rennlist Discussion Forums   classifieds | membership | rennlist | photo album
sponsors | upload photo | chat
Go Back   Rennlist Discussion Forums > Water Cooled Technical Discussion Areas > Porsche Cayenne Forum
Sign in using an external account
Register Forgot Password?
Search
Thread Tools Search this Thread
Old 01-11-2011, 10:13 PM   #1
Mister Quickie
Mister Quickie's Avatar
Default Is the Cayenne always 4wd or does it have to be switched fr 2wd to 4wd?
snow/sleet tomorrow and the x is letting me use her cayenne v6. the other time i drove it there were these other two drive modes (cannot shift to on the fly, must be in neutral to shift) which were real slow, perhaps designed to get out of tough areas.
the question is whether the cayenne, in its' normal driving mode, is a 4wd or is a 2wd and in order to utilize 4wd has to switch to one of the other modes?
TIA
To remove this ad, register today or login if you already are registered!
Mister Quickie is offline   Reply With Quote
Old 01-11-2011, 10:34 PM   #2
mudman2
Moderator !x2
mudman2's Avatar
Send a message via Yahoo to mudman2
always
Mike
08 Cayenne Twin Girls
Marine Blue Metallic, Havanna/Sand Beige Full Leather, Clear Side Markers, MoBridge/BT
gallery
To a new home with 130K -04 Cayenne S, Titanium Metalic / Black, PCM Air, BMC Air Filters, FabSpeed Cat Bypass Pipes and Dual Tips. MoBridge iPod / Sirius and BT
gallery
mudman2 is offline   Reply With Quote
Old 01-11-2011, 10:40 PM   #3
Dennis C
A Texan in the Mountains
Dennis C's Avatar
Dennis Cassell Texanhoosier
It's actually full-time AWD, which is the best application for on road driving. My old Ford Bronco was 4WD!
Dennis
Porsche Cayenne S
Porsche Carrera 4S
Dennis C is offline   Reply With Quote
Old 01-11-2011, 11:21 PM   #4
JFScheck
JFScheck's Avatar
Sometimes refereed to "AllWheelDrive" vice on something such as a F-350 which is "4WheelDrive" where you have lockers on the wheels - either manual or automatic from inside the cabin....
JFScheck is offline   Reply With Quote
Old 01-12-2011, 01:28 AM   #5
medtech
medtech's Avatar
Porsche AWD generally sends about 5% to the fronts under normal driving and will automatically adjust as needed, sending up to 40% to the fronts. (I think those #s are correct for the Cayenne, or I might be getting it confused with the 4S).
Stats:
Current
'11 Spyder
'06 Cayenne S
Past
'06 Cayenne V6; '05 996 C4S; '02 Boxster S
Understeer is when you hit the wall with your front end. Oversteer is when you hit the wall with your rearend. Horsepower is how hard you hit the wall. Torque is how far you move the wall.
"Dog is my Co-Pilot."
medtech is offline   Reply With Quote
Old 01-12-2011, 12:43 PM   #6
993BillW
993BillW's Avatar
Curious, does PSM Off change any of this?
Bill
Thanks to Jager for avatar pic
'97 993 C2 Coupe, Arena Red/Black
'10 Cayenne GTS
'13 VW Golf R (the dog's ride)
past Porsche's....993 cab, '88 911, 968 & 955
993BillW is offline   Reply With Quote
Old 01-12-2011, 01:02 PM   #7
mudman2
Moderator !x2
mudman2's Avatar
PSM is "Please Save Me " and will come on by itself if your trying to do something outside the safe operating envelope. The only time things change is when you start locking things up but thats more 4 wheel drive and not less
Mike
gallery
gallery
Old 01-12-2011, 01:29 PM   #8
993BillW
993BillW's Avatar
Quote:
I meant does turning PSM off change the front to rear bias?
I've only used low range (a transfer case function) a couple of times, once was getting a neighbor's truck un-stuck.
Bill
'10 Cayenne GTS
Old 01-12-2011, 02:00 PM   #9
mudman2
Moderator !x2
mudman2's Avatar
No the system operates the same with PSM is on or off
Old 01-12-2011, 03:50 PM   #10
mmmbeer
User
mmmbeer's Avatar
Quote:
There are two different systems on the 911 and the Cayenne. The one you are refering to is on the 911.
The system in the 911 is more aimed towards stability for sporty driving on wet surfaces than offroad use. While the Cayenne have a proper offroad system. The standard ratio is 38/62 (ref MY 06 manual).
If you push the handle on the Cayenne one more time after selecting low range you will lock the center differential for a fixed 50/50 front/rear ratio.
mmmbeer is offline   Reply With Quote
Old 01-12-2011, 05:08 PM   #11
yeldogt
I thought my 996tt had 35% going to the front wheels all the time? The car is unbelievable in the rain.
Some of the Cayenne's have an additional lock - mine is just the standard two step and I almost never use it. The reduction is a bit high for snow.
yeldogt is offline   Reply With Quote
Old 01-12-2011, 05:43 PM   #12
rome
rome's Avatar
I thin the standard ratio for the Cayenne is a little different for MY '11 (more along the lines of the Carerra), with power going to the FWD, "as needed." It is discussed here: http://press.porsche.com/vehicles/11...eup_update.pdf
'11 Cayenne S-- Jet Black/Black Full Leather
'06 Cayenne S -- Basalt Black/Black Full Leather (Gone )
'97 993 C2S-- Ocean Blue/Cashmere
rome is offline   Reply With Quote
Old 01-13-2011, 11:48 PM   #13
medtech
medtech's Avatar
Thanks Beer!
I hope I can remember how to lock the diff when I actually need it.
Stats:
Current
'11 Spyder
'06 Cayenne S
Past
Paid Advertisement
Tags
2011, awd, cayenne, center, differential, drive, driving, full, locking, mode, porsche, snow, time, wheel, work
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2014, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.5.2
Copyright ę 1998 - 2007 Rennlist.com
Advertise on Rennlist - Privacy Statement - Terms of Service - Jobs
Emails & Contact Details
