Rennlist Discussion Forums   classifieds | membership | rennlist | photo album
sponsors | upload photo | chat
Go Back   Rennlist Discussion Forums > Water Cooled Technical Discussion Areas > Porsche Cayenne Forum
Sign in using an external account
Register Forgot Password?
Search
Thread Tools Search this Thread
Old 04-09-2011, 01:35 AM   #1
gte
User
Default Deleting vs. Removing Model Designation
When ordering I discussed with the dealer the option of having the Cayenne left off. He said I could do that or have it removed after it arives.
The question I have is, if I have the factory delete the model designation will the PORSCHE be placed in the same position as it will be if I have the dealer remove the Cayenne after delivery?
To remove this ad, register today or login if you already are registered!
gte is offline   Reply With Quote
Old 04-09-2011, 04:01 AM   #2
Galion
User
Galion's Avatar
The Porsche logo will be centered If you have the model designation delete.
Check the 3D configurator at the Porsche website.
Galion is offline   Reply With Quote
Old 04-09-2011, 05:50 AM   #3
slwong23
I think PORSCHE is placed in the same position either way. I removed the model designation myself, below is a pic. Looks pretty centered on mine.
slwong23 is offline   Reply With Quote
Old 04-09-2011, 12:00 PM   #4
GBX
User
GBX's Avatar
Send a message via AIM to GBX
I had asked the same question when ordering mine. No one seems to be 100% sure but it sounds like they may move it down a few mm's.
I went ahead and ordered with model designation deleted. Go for it! Much cleaner IMO.
Good luck!
GBX is offline   Reply With Quote
Old 04-09-2011, 02:53 PM   #5
gte
User
I figured on removing it after it arrived, that way when I sell the car if someone wanted it on I could just give it to them and they could put it back in place. I then started thinking that the PORSCHE may not end up centered that way. Looks like it would be pretty much in the same spot either way. Does anyone know for sure?
George
Old 04-09-2011, 03:24 PM   #6
rijowysock
rijowysock's Avatar
Send a message via AIM to rijowysock
easier to delete, it's placed on the fresh paint.. so sometimes the paint comes up with the adhesive in spots, even when using thin floss and a heat gun, and the glue is a pain to get up...
its free to delete, i like mine without it.
Rijowysock@gmail.com
rijowysock is offline   Reply With Quote
Old 04-09-2011, 06:08 PM   #7
autobahnA8
we deleted ours. looks cleaner in my opinion.
autobahnA8 is offline   Reply With Quote
Old 04-09-2011, 07:05 PM   #8
Galion
User
Galion's Avatar
I would remove it only in a base Cayenne
Old 04-09-2011, 10:06 PM   #9
slwong23
Quote:
You're one of those... Anyone who knows anything about the car can easily tell the model by the calipers or front end. And if they don't, seeing the badge on the back won't mean anything anyway.
Keep the model on the back if you like it, delete/remove it if you prefer the look without it. I personally prefer the simpler look after seeing many pics of the 2011s without the model designation, therefore chose to remove it after the fact.
Old 04-09-2011, 10:34 PM   #10
rijowysock
rijowysock's Avatar
side note:
the delete made my PORSCHE, lower... just noticed today, looks lower than the guy above.
as far as "base" models.. if you know there is a diff in cayenne's im pretty sure they also know about the brakes... or the front side vents (ironic however, painted side vents on S=1120$, painted side vents on base=free)
i deleted mine not because it is a base but because it was a lot going on back there, even on my carrera i removed it for "911".. deleting everything looks bare imo.
Old 04-09-2011, 10:57 PM   #11
slwong23
Riley- do you have a close up shot of the back of your Cayenne, given you had the model delete in your build? I was trying to compare mine to one of w00t's pics, but wasn't able to see the difference.
Old 04-10-2011, 01:26 AM   #12
gte
User
Called the dealer today, I'm past the point where I can make any changes. Looks like I'll just have to have it removed when it arrives.
Old 04-10-2011, 01:50 AM   #13
slwong23
I'm sure the dealer will do it for you free of charge. If not, it's really easy to do on your own. I used a blow dryer to heat the badge, dental floss (fishing line would be better) to get behind it, then a little wd-40 to remove the remaining adhesive. Probably took me a total of 20 mins.
Old 04-10-2011, 03:06 AM   #14
rijowysock
rijowysock's Avatar
Quote:
looks lower right?
Click the image to open in full size.
i like floss better, the fishing line scores the paint sometimes, floss will tear up, i use the flat stuff and keep the spool there and keep using new area's...
Old 04-10-2011, 07:24 AM   #15
slwong23
Yes, it does look slightly lower... thx for posting.
Paid Advertisement
Tags
base, carrera, cayenne, deisnation, delete, deletion, designation, model, order, paint, painted, porsche, remove, today, v6, woot
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2014, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.5.2
Copyright ę 1998 - 2007 Rennlist.com
Advertise on Rennlist - Privacy Statement - Terms of Service - Jobs
Emails & Contact Details
