classifieds |
membership |
rennlist |
photo album     sponsors | upload photo | chat     |
Sign in using an external account
Thread Tools | Search this Thread |
#1 |
Rennlist Member Join Date: Mar 2004
Does anyone know how this function works or what causes it to be activated? I've had 2 incidents in my 2012 CTT where the brakes are suddenly applied without any warning and ACC was NOT engaged.
Under both circumstances there was no eminent danger or loss of traction. 1st time occurred on the freeway and second time on surface streets... I'm beginning to think there's a SW malfunction or sensor issue on the car. TIA. J
Member # 050419-5672 |
#2 |
User
Hey JMK,
Were you applying the brakes at all in the incidents? If you weren't applying the brakes, you may be correct, software issue. Good luck! |
#3 |
Did not apply the brakes in either event.
#4 |
Rennlist Member Join Date: Jun 2001
Emergency brake assist works by interpreting how quickly and with what force the brakes are being applied. If it senses the driver is attempting an emergency stop without applying full brake pressure, it takes over and applies the brakes fully. Bottom line in your situation, though, is that if you are not touching the brake pedal, and the brakes are being applied anyway, you definitely have a problem.
Mike 2009 C2S | PDK | SPASM | PSE | Sport Buckets | BK Harness Bar | Schroth 6pt belts | Arctic Silver/Cocoa 2011 Cayenne S | PDCC | PTV | PASM | AS | PSE | Sand White/Umber 2011 Audi A3 TDI |
#5 |
FWIW, here's what I found out about "active safe" system from service.
"Although ACC may be switched on and off , at speeds > 20mph" Porsche Active Safe" may still intervene. The Radar sensor is employed and several different warnings used , up to an " Acute warning " that uses a strong brake jolt to alert the driver to a possibly hazardous traffic situation. " Active Safe " complete function and prewarnings can be switched on and off independently".
#6 | |
Quote:
#7 |
No worries Mike! I don't think anyone at service new about this new feature until they contacted an engineer at Porsche in Germany. It's easily deactivated on the dash in the settings menu. Hopefully, that will do the trick!
#8 |
User
JMK: I have the active cruise control with the pre-safe system activated. it works when it's supposed to... i've seen it. but if yours is not working at the right time, have it checked. it should be accompanied with a warning when it activates as well... it surprised me yesterday and did a brake jolt when the cars in front of me stopped quickly. surprisingly it only does it when the risk of collision is VERY near. i would have yours checked out. or try cleaning the front sensor, just to be sure.
#9 |
User
Do you have some type or radar detector or laser jammer installed? Some have been known to interfere with LCA, but could be related to your issue.
| Tags |
| 2012, alert, assist, brake, braking, breaks, cayanne, cayenne, ebrake, emergency, parking, porsche, porsches, system, wheres |
