1st oil change in Cayenne Diesel
7th Gear
I just had my first 5,000 mile oil change in my Cayenne Diesel AND it was the first oil change that the dealership has done as well. The guys said it took about 3 hours (glad I scheduled a loaner for the day) and it ran me about $300. It's kind of a pain every 5,000 miles - my dealership is almost an hour away but it's worth it because I love the car. The issue is that now, 3 days later I have a warning light on that says "oil level above maximum". I spoke to the service dept and they told me to drive it around and see if it goes off. Has anyone had an oil change yet in the diesel? Any issues with the oil change??
I think I'd be waiting at that dealers service bay the next day. Overfilling is worse than running a little low.
*** I have no knowledge of diesels though, they may tolerate overfilling better than gas engines (but I doubt it). If it's enough to trigger the warning light it's enough to have it addressed by the dealer, IMHO.
Former Vendor
Are you frickin' kidding me?
This issue definitely needs to be addressed sooner then later and I wouldn't think it shouldn't be driven around.
I have a 2013 v6, when I received it brand new ... the overfill warning came on once every two days for a few minutes.
Called dealer, and they said "normal ... give it a week and bring it in if it does not go away". Went away after a week as predicted.
I have also read several other reports on the boards, about the intermittent overfill warning, usually with the "dealer says normal" and "it goes away".
Joys of no longer having a real dip-stick, to double check!
Things would be so much simpler if they just gave us back the frickin' dipstick!!!!
I strongly suggest you read up on oil changes in your owner manual. It's almost unthinkable - given the technology of the engine/oil/filters - that you'd have to change every 5k. Unlike the gasoline only Porsche models, the diesel and the hybrid engines have oil quality sensors. Other than changing the break-in oil on you diesel @5k, you don't have to change again until the car computer tells you. Mine says 5k right now, followed by another @20k - unless my driving habits make the computer tell me otherwise.
All this by the way, is predicated on your using C30 oil and Porsche-approved filters. The warranty does NOT necessitate it be done at a Porsche dealer. If you provide the correct oil and filter, there's no reason you can't have it done at any quick change place for $35 - or whatever the going rate is these days.
//greg//
//greg//
Just call me Pops
And I'd strongly suggest that you'd not let your car be worked on by anyone at the "quick change place". Do some research and find a reputable independent mechanic in your area instead.
7th Gear
//greg//
//greg//
7th Gear
Just call me Pops
Again, refer to your owner manual. The next recommended service will already be identified in your MFD. I can't speak for your driving conditions. But based on mine, the MFD says the next oil interval after the break-in change isn't until 20k
//greg//
//greg//
//greg//
I read the 5k interval here so I asked my dealer about it when I picked mine up last week. He referred me to the maintenance guide which says 10k. He also asked his tech who just got back from training on the diesels and he said the same.
I'll do my first at 5k, then after that it will be every 7-10. If my local shop wants $300, that'll be plenty on incentive to do it myself...
