"NEW" Cayenne Aluminum & Carbon Fiber Drive Shafts
Basic Sponsor
Lindsey Racing now carries both Aluminum and Carbon Fiber Drive Shafts for your
'03 thru '08 cayenne. V8 Models only.
Currently there is a two week build/ship wait but we will be keeping then in stock for immediate shipment soon.
http://www.lindseyracing.com/LR/Parts/955AXLE.html
The shafts will replace the notorious hanger bearing issue and also eliminate the front Guibo (rubber drive).
If you have questions, we will try to get them answered quickly.
- Lindsey Racing
- Lindsey Racing
Mike or Dave Lindsey
U.S. 1-877-943-3565
Other 1-405-947-0137
U.S. 1-877-943-3565
Wait, what?
How is this different from the cardan shaft? And, if it's the same thing by a different name, why is it V-8 compatible only? What am I misunderstanding here?
I'm thinking due to the weight savings there is no need for the center support Bearing anymore? Definitely less mass out there. I can say I've had great luck with Lindsey products for my 944T and 911. There modified 17" Fuchs are popular. Not sure I want to be the first person though.
P.S. Going by their website shipping weight numbers I see stock: 28#, Aluminum 23#, Carbon Fiber 20#.
Basic Sponsor
Yes being its a single shaft you will have a more responsive feel to it. With the stock shaft the Giubo has to twist a little, then the hanger moves and after all that the vehicle will move. Being its more or less solid after it will be more responsive or athletic feeling.
Basic Sponsor
Basic Sponsor
The term Cardan is in reference to a u-joint or double u-joint style shaft you would see under older 70's GM car and some newer Trucks. The Stock shaft has a rubber Guibo at the front, then the hanger and after that is has 2 CV's like the ones were using on each end. This pretty much removing the "problem" parts and making a single shaft.
Basic Sponsor
Basic Sponsor
We do business worldwide and can ship to anyplace DHL, UPS or the Post Office will deliver to. Nobody stocks these yet, including the manufacturer. Currently there is a 2 week build to ship time. We will stock when they start moving so people can get one ASAP.
