Cayenne jack Puck pad
Old 04-20-2014, 09:27 PM
solrac6262
solrac6262's Avatar
Default Cayenne jack Puck pad
where can I get a jack pad puck for my 14' CD
thanks
Old 04-20-2014, 11:58 PM
BlazinPond
BlazinPond's Avatar
Out of curiosity.....what is a jack pad puck?
Since i jacked up my CTT to swap out winter/summer wheels today, i'm curious.
Old 04-21-2014, 10:39 AM
kosmo
kosmo's Avatar
I dont have one for the Cayenne and dont know where to find them. Currently Im using a squarish piece of thick rubber. I use a hockey puck on the 911.
heres what a pad looks like :
Amazon.com: BMW Jack Pad Adapter by BMS - 135 335 535 E82 E88 E46 E90 E91 E92 E93 E38 E39 E60 E61 E63 E64 E65 E66 E70 E71 E89 F01 F02 F30 F10 E83 X5 X6 X3 1M M3 M5 M6: Automotive Amazon.com: BMW Jack Pad Adapter by BMS - 135 335 535 E82 E88 E46 E90 E91 E92 E93 E38 E39 E60 E61 E63 E64 E65 E66 E70 E71 E89 F01 F02 F30 F10 E83 X5 X6 X3 1M M3 M5 M6: Automotive
Old 04-21-2014, 11:36 AM
pdxjim
pdxjim's Avatar
I have the same model as OP and changed out my snow tires with a puck. Before the puck, I would use a square piece of hard wood.
Old 04-21-2014, 07:01 PM
duh
duh's Avatar
At work on hoists we generally use hockey pucks, otherwise if need be thin rubber mats that came with the hoist accessories. Hockey pucks work great.
Old 04-21-2014, 08:28 PM
mudman2
Moderator !x4
mudman2's Avatar
2x4
Old 04-22-2014, 11:31 PM
solrac6262
solrac6262's Avatar
I have that BMW jack pad it does fit on the square slot, but I was afraid that the square part was not tall enough and the round part actually was holding the weight, might be wrong, I'll cut the 2x4 tomorrow thanks all
Old 04-22-2014, 11:33 PM
solrac6262
solrac6262's Avatar
BlazinPond, what do you normally put on your jack ?
Old 04-23-2014, 10:37 AM
Slow Guy
Slow Guy's Avatar
ECS has this kit for the Audi/VW platforms, I wonder if they have something like it for the Porsche platforms?
I have that kit installed on my Golf R but I still use 2 hockey pucks on top of either the jack base/cup or the lift arms (whichever lifting source I'm using at the time).
Old 04-23-2014, 11:37 AM
stu11926
stu11926's Avatar
Amazon.com: Prothane 19-1405-BL Black 5" Jack Pad: Automotive Amazon.com: Prothane 19-1405-BL Black 5" Jack Pad: Automotive
Also, Harbor Freight sells cover pads for jack stands: http://www.harborfreight.com/2-piece...and-95952.html
I couldn't find the item online, but I'm pretty sure they have the floor jack pads in the same place in their stores for even cheaper than Amazon.
Old 04-23-2014, 10:45 PM
BlazinPond
BlazinPond's Avatar
I use a few layers of thick, heavy duty cardboard wrapped/secured in duck tape around the jack plate. It provides some cushion so as to prevent damage in my estimate.
My jack is top notch (Hein-Werner), but if i can find a more professional 'pad', i am open to improvements here....which is why i was curious and commented above.
Old 04-23-2014, 11:21 PM
solrac6262
solrac6262's Avatar
I was thinking that you need something to fit in the square hole no? that cardboard actually lifts your suv from the plastic ?
Old 04-23-2014, 11:32 PM
CaptJim
CaptJim's Avatar
No, I e-mailed them to ask
I like the idea of a Hockey Puck
Old 04-23-2014, 11:40 PM
Slow Guy
Slow Guy's Avatar
Just make sure you use "authentic" hockey pucks, not street pucks. When I bought mine (online) a few years ago it was about this time of year and the store was clearing them out so they doubled my order at no additional cost. Nice of them.
Old 04-23-2014, 11:46 PM
YRUNVS
YRUNVS's Avatar
Default jack adapter
Hi made this for my floor jack from a high strength construction bolt. It screws into a pipe end plate cover in which a threaded hole to match the bolt was machined. The top swivel block is machined from stainless steel and fixed through a hole near the top of the cut off bolt with a steel rod. It is held in place with a rolled pin. I provides about 20 degrees of tilt in each direction. The whole assembly just sits in the cup of the floor jack. Hope I loaded the pictures correctly!
Quick Reply: Cayenne jack Puck pad
