997 Cup Power Steering Fluid Level
Hi,
Is the small white upper filler reservoir (circled in yellow) just for overflow or should the power steering fluid level be filled all the way up to the white little container between Min and Max or should it just be close to the top of the reservoir down below as it is currently?
I used a turkey baster and sucked out the old fluid and put in fresh and put it back to the level it was at, but after reading I wasn't sure this was correct.
